Results 1 to 7 of 7
    Jun 2020
    Prince Edward island
    Default Radio issue - can't change to FM Band?
    Good day
    I'm new to the spyder world
    I ride a 2011 Rt
    My radio is stuck on AM
    Tried disconnecting battery at different intervals
    Still stuck
    Mode switch still scrolls
    Just wont come out of AM
    Is it a switch on handgrip?
    Or radio?
    Thanks
    Nov 2018
    Waynesboro, PA
    If your controls are working for everything else (scroll and up and down in the menu) then I would say it is a radio issue. Try unplugging the radio and making sure the connections are clean than reconnect the radio. The radio in right under the right passenger hand rail.
    My Spyder
    2012 RTL , Brown
    Quote Originally Posted by Partsguy View Post
    Good day
    I ride a 2011 Rt
    Still stuck
    Or radio?
    Thanks
    On my 14 RT, I have an AM and FM choice + Aux. and NOAA weather. .... I think you have the same choices ..... Look in your preferences screen display. ....... good luck .... Mike
    Jun 2020
    Thanks I have tried all connection's and disconnected battery too. I guess it's the radio
    Jun 2020
    Thanks mike
    Thanks mike
    Do did you find how to change to FM ????? Mike
    Jun 2020
    Yes I did
    I was able to do it when I first bought the bike
