Results 1 to 19 of 19
    Mar 2013
    Mount Vernon,MO
    Default seat latch problem
    I have a 2019 Rt Limited. When I try to lift the seat for refueling, I have to grab the right side of the seat and pull up sharply to get the seat to unlatch. Is there an adjustment I can make to make the seat release smoothly?
    Nov 2018
    Waynesboro, PA
    Yes you can adjust the pin under the seat a little to line up with the latch. Make sure your seat is in place and tight (not lose in the back). you should be able to loosen the pin under your seat just a little and bring your seat down so you can see how it lines up with the latch. Pin and latch is on the right side. once you have it lined up by sight tighten the pin back up and try it. when you turn the key it should popup if your seat shock is good.
    My Spyder
    2012 RTL , Brown
    Mar 2015
    forrest above Reno, Nv
    At least on my 2014 RT there is an adjustable bolt under the seat. But 2 things:
    1. Lube the release mechanism.
    2. Add a safety release for/if the key procedure fails.
    Is the gas strut strong enough to lift the seat???? If not -- there are replacements.
    Good luck,
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2017
    Durham,Maine
    2012 RTL , Pearl
    Jul 2014
    Mint Hill, NC
    X2! Matter of fact, when I took possession of my Spyder with Comfort Seat there was a bit too much slack in the adjustment of the seat lug, the fixture that latches to the Spyder frame, and I had to adjust it.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2018
    Yuma
    I have found occasionally lubricating latches, release mechanisms, locks, ignition switch and so on with a 3-in-one product called Lock Dry Lube. I buy mine at Walmart, in a 2 1/2 oz spray can about 5" high. It really works well, I hope this will help you.
    Feb 2019
    Portland, Oregon
    After seeing many posts about this, I attached a fine cable to the seat and frunk latches and never use the key.
    Aug 2008
    Maryland
    If its no bother - I'd appreciate a description and pictures of your setup
    Cheers Mate
    Steve
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Sep 2017
    Durham,Maine
    Quote Originally Posted by BeRight View Post
    Cheers Mate
    Steve
    Try the search engine right corner, there's all kinds of post on this!! good luck
    2012 RTL , Pearl
    Feb 2019
    Portland, Oregon
    Here's a photo of mine on the frunk latch. There's little black knob on the end and I have it just peeking out from under the lid.
    Aug 2008
    Maryland
    Cool- thank u
    Mar 2019
    NEBRASKA
    Any ideas on a safety release for the seat latch?
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Dec 2013
    Quote Originally Posted by davev1pa View Post
    Sure! See RICZ's post #10 with pic above - exactly the same concept, just a shorter 'Emergency/Safety Release' lead!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Apr 2019
    Clinton, MS
    Cheers Mate
    Steve
    Try this post for more info. https://www.spyderlovers.com/forums/...15#post1508815
    Aug 2008
    Maryland
    Thank u - just what I was looking for - search leaves allot to be desired
    Active Member LongIsland's Avatar
    Dec 2018
    Long Island
    On my 2014 I had problems with the seat latch in 2015 so I removed the pin and have had no issues in 5 years.
    Default Seat latch pin ....
    Quote Originally Posted by LongIsland View Post
    Maybe this will never happen to you - the seat sliding forward and the front seat " wings " coming in contact with the plastic at the rear of the Glove area. .... But as a Vendor I have seen this occur ..... it will remove a bit of paint if it occurs ..... The Seat pin is what keeps the seat from moving IF the rear Seat bolts/nuts get loose. It's fairly easy to add a cable to both the frunk and the seat latch, and using these instead of the ignition switch. ... This will prevent the failure of the OEM system ie. ignition switch cables, from breaking or falling off ( it has happened as posted here many times )...... good luck .... Mike
    Active Member Clary's Avatar
    Feb 2015
    Nova Scotia canada
    I to have added the emergency pull cord to the latch, 5 min job and hope I never have to use it.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Clary View Post
    I only use my pull cords. More convenient, easier and why risk a mechanism that's inconvenient to replace?
