Results 1 to 14 of 14
    Active Member Sccar's Avatar
    Mar 2015
    East Texas
    Default Can I adjust the Handlebar angle!?
    can you loosen the 4 bolts on the handlebar and move it up a few inches?
    2015 F3S SE6
    You don't stop riding because you get old, you get old because you stop riding
    2015 F3s , Orange/black
    May 2019
    Port St. Lucie, Florida
    Sure. Don't get carried away, though. I moved mine once, and it affected my transmission. I guess it was stretching a cable, or something. Also, When I raised mine, it resulted in terrible back pain. I was really surprised. I thought it would help.
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Feb 2019
    Portland, Oregon
    I lowered mine with no problems.
    Mar 2017
    Put mine as far forward as would the OEM allow. Love it. Better reach and I don't get cramps in my hands. I have 3T which means I moved the meat into the mirror field. Can't see anything unless I duck or stretch. I put a set of bar end mirrors on which I like a lot (they dampen vibrations).
    Mar 2015
    East Texas
    Thank you All for the feedback.
    2015 F3S SE6
    Aug 2008
    Maryland
    u probably already know but just in case: make sure that all cables are easily moving while your moving handle bar - some of them are rather short and are tied really tight to handle bar and further down in bike and offer very little relief. Pulling them can break them loose from there end or handlebar connection.
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Sep 2020
    Ontario, Canada
    Loosening some may be as simple as removing a zip tie. You will see when you look closely.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Terrance View Post
    OMG! Now BRP is cheaping out using twist ties instead of zip ties?? What's next, used tires?
    Sep 2020
    Ontario, Canada
    God you're fast, I realized and edited it as soon as I saw it up. LOL
    OMG! ....... What's next, used tires?
    No Way RICZ!! They've already found something EVEN CHEAPER and factory fit them for your ryding enjoyment!
    Mar 2017
    Don't they come with used tires already? Less than 10 k on a rear tire is pitiful.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Rattlebars View Post
    Actually a blessing in disguise. Now you can replace that "used tire" with a top notch one.
    Mar 2017
    My choice was a Kumho ECSTA AST 225/50R15 with Toyo Proxes T 185/55-15 up front.
    Apr 2016
    Portland
    What are them mirrors called or the the make of them, been looking for something like that for a while.
