Page 1 of 2 12 LastLast
Results 1 to 25 of 34
    Feb 2014
    Orland Park, IL
    Default 2020 RT Saddlebag Sticking
    The left saddlebag on my 2020 RTL will not pop open as it should when I pull the lever. If I put inward pressure on the saddlebag while pulling the lever, it will open. Is there some kind of adjustment I can make to fix this?
    Danbury Connecticut
    Interesting.
    I've got the exact same problem with the right saddlebag.
    I had a similar problem with the frunk lid and seat, but those were easily adjustable.
    Any help from anyone would be appreciated.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Aug 2018
    north wis
    I had same issue and had dealer handle it. Tech said one side was easy other not so much.
    Central Oklahoma
    And pulling on the latch on my 2020 when the saddlebag stuck is what broke the latch. when the dealer finally gets the parts, I am going to put some silicone dry electronics lube on the rubber seal.
    2020 RT Limited , Petrol Metallic Dark
    Sep 2017
    Durham,Maine
    Some times I think it's the seal, that's holding out on the cover just enough to stick the latch, and just a tap with the knee will pop it! Some times it's what you have inside doing the same thing and a knee or small push of the hand will pop it! But I also go around at least every year and give everything a spray of wd40!
    2012 RTL , Pearl
    Feb 2014
    Orland Park, IL
    Mine is exactly the same. Pressure with my knee while pulling the lever gets it open. I have used WD40 on it and it helped a bit, but I sure would like it to open like it should. I'd hate to have my underwear in that saddlebag on a trip if I couldn't get it open. I guess if there is no easy fix, I can bring it to the dealer.
    Active Member will's Avatar
    Mar 2012
    Harpers Ferry, WV
    I have the 2020 Spyder RT and the left saddlebag will not open so I will try the knee method.
    2020 Limited , Petrol Metallic
    Jul 2010
    Las Vegas, NV
    Get a flashlight. Lie down so your head is under the front of the saddlebag. See the cable adjuster. Hold the one end and unscrew the other one full turn. Try the latch. If still sticking, one more turn. The right side is harder to get to, as the muffler is in the way. The cable adjuster has a knurled stopnut. Loosen that, first. After the adjustment, tighten the stopnut. Cables stretch. Pretty easy fix.
    Joe Meyer
    Sep 2017
    Durham,Maine
    Quote Originally Posted by cptjam View Post
    Thank You!!!!!
    2012 RTL , Pearl
    Jul 2010
    Las Vegas, NV
    Just did another one. Easy fix. Anybody needs help, call me. I’ll walk you through it. Joe
    Joe Meyer
    Mar 2012
    Harpers Ferry, WV
    cptjam,
    Worked great, thanks.
    Will
    Jul 2010
    Las Vegas, NV
    I am happy to help. I forget sometimes that everybody is not able to get help locally, and dealers can be hours away. Our friend just pointed this out; what we do regularly is a challenge to some. I’m just happy to help. Joe
    Joe Meyer
    Jan 2020
    New York
    Just made the adjustment on the right side per Joes instructions and worked like a charm!
    Thanks for the great advice!
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    Feb 2014
    Orland Park, IL
    Thanks Joe. Worked great.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    That worked perfectly for me too. Thanks a bunch Joe!
    Now if I can get my dealer to fix the misaligned pull handle assembly on the left hand case. I got the new plastic installed by the dealer and it doesn't fit all that well either. They have a call into BRP tech support and they've been radio silent for weeks now.
    2020 RTL SE6
    Jul 2010
    Las Vegas, NV
    Bring it to me Friday. I’ll take a look. Ann’s looked horrible, and we finessed it. We are in St. George. Joe
    Joe Meyer
    May 2021
    Texas
    FYI. On my new 2020 RTL (it was in a crate at the dealer, and that's why it is new) I have had it in to the dealer for several issues, including the main computer going out while I was on a trip to Big Bend National Park which is 350 miles from home in San Antonio. The trunk lid would close and the lock would turn, but it was not locked. The dealer "fixed" so now it locks, but I have to slam it so hard I am afraid of breaking that thin plastic. Also, the side bags would not open. The handles would not pull open. So, it went back to the dealer, and they fixed those. Stayed fixed for a couple of weeks before having the same problem. New cables are on order from Canada. I did your fix (thanks) and it works most of the time, but maybe there is rust in the cable? I did get them to warranty add a damper on the drive belt and that fixed the 4100-4500 vibration. Whew. I thought these maintenance things would go away with a new Spyder...
    Active Member SpyderGoldwingOwner's Avatar
    Jul 2021
    Texas
    On my wifes new 2020RT the left sticks a bit. A light push to close it harder works. We rarely open it & I have been opening the latch every ride which seems to loosen it up.
    I would NOT RECOMMEND WD40 applied to plastic parts as suggested above. Silicon spray is safe
    2020 Can-Am Spyder RT
    2018 Honda Goldwing DCT
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    Yep, me too - have to do the knee thing. I'll try the fix, thank you.
    2020 RT Limited in the ultra cool Deep Marsala Dark edition.
    Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
    Maintained by Lou at Pirate Powersports.
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    Mine were tough to open also. Finally the right side handle broke off. Brought it to my dealer, "We just broke one doing the prep on a new bike". No problem, we will warranty yours. Oh, "that was the last handle we had". "Seems we had a few recently". They will also adjust the other side for me. Now, I wait with one bag unusable. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Active Member Schreckftw's Avatar
    Oct 2020
    OH
    Just got mine back last week from the dealer for the same issue. Worked great last week. Sticking again this week.
    2021 RT Limited , Deep Marsala Red Metallic (Dark)
    Jun 2021
    62431 Illinois
    Thumbs up
    Quote Originally Posted by will View Post
    Try some lube or dry slide on latch mechanism, worked on my 2017.
    Oct 2020
    OH
    Reached under and could feel the what you are talking about. Was able to adjust them so easy. Now they open better then they ever have before. Thanks so much for the post.
    Nov 2020
    Pa.
    2020 RTL Here we go again! My left side storage compartment won’t open. I know how the adjustment works, it’s given me problems before. Flashlight, on my back reach up adjust a little a couple times both ways no change, so I pull on the side that goes up to the latch ( not the handle side ) and IT DECIDES to open but the cable breaks inside the harness. I look up the OEM cable replacement and it’s $114.00. Do you guys think maybe it might be covered by the warranty?
    I’m in Queensbury NY as we speak at the annual Spyder Quest and have had the opportunity to question quite a few 2020 and 2021 owners about this, only 1 said he hadn’t. All the others had issues of some kind with them.
    Aug 2012
    Central Coast, CA
    To my mind it should clearly be a warranty issue, but the dealer is the gatekeeper to all things warranty so I'd talk to them about it before they wrote it up to see what they have to say. If they're being difficult move onto the next dealer since nothing would be in writing at that point.
    Just a thought.
    2020 RTL SE6
