Results 1 to 12 of 12
Thread: vibration at 70
    Sep 2020
    Tuttle, ok 73089
    Default vibration at 70
    I have heavy vibration at 70 mph like engine or drive train. the tech tells me it is normally with the spyder. I don't believe it. Its like the drive train or engine is about to blow a piston.
    Any ideas from anyone or does anyone have the same problem?
    Most likely belt vibration. Very common. You feel it in your foot pegs.
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Having the belt tension done during first service fixed mine
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Mar 2015
    forrest above Reno, Nv
    Hi feb,
    Always good information to know the year and model of you
    2014 RTS , Circuit Yellow
    PA
    Welcome to spyderlovers! Same thing with my 2017 RT limited. I put up with it for the longest time especially when my wife rides with me. Last week I decided to adjust the belt tension. I tested the belt flex and loosened it a very little bit. Ran it and the vibration dropped to 68mph. Then tightened it like some others recommended and it raised to 72mph. I installed a belt tensioner from Lamonster with the XL roller and its gone immediately. I didn’t even tell my wife and she noticed it without being told. It takes 20-30 minutes to do total from ripping off the plastic, installing the 2 bolts, and putting the plastic back on. The bearing may be a wearable item but I have no problem replacing it every other oil change. I took it off ECO and man o man you could really notice the difference. My spyder is so smooth riding all the way to 90mph. I really ripped on it to see if I could find any vibration and it is gone. I would never need 90 but was curious and no vibration.
    Jan 2015
    southern WI
    Likely belt vibration as mentioned. A good tech can adjust your belt to make it stop, to a point. There are factors of course that cause the vibration at given speeds under certain loads, but pretty much every Spyder does it at some point. It's a matter of what you're willing to live with. There is a never ending debate on how tight the belt should be, because of a fine line between drive damage, and vibration. You can choose to run the tension at a lower than recommended tension, and then add a vibration dampener, like many have done, myself included. Even with the tensioner, I still get a lower degree of vibration at a pretty precise speed. I just speed up or slow down a couple MPH's
    2016 RTS , Pearl White
    Jul 2019
    Blk Hills & MN
    I also just put a Lamonster tensioner on & discovered the tensioner helped allot! Stick your head down there sometime and look at that drive belt length. It's about 3 feet long on top and bottom! Holy crap! no wonder there can be belt-flapping with that distance....IMO.
    2014 RT Limited with Chrome pkg
    Durham,Maine
    Try to have your belt adjusted before you decide to jump to the tensioner, my take is keep it simple, less to worry about! But if you do put one on, remember you have to check the bearings in that wheel like you check your oil, give it a spin by hand to make shore it's not getting dry and blow a belt!! My 2 cents on that!!!
    2012 RTL , Pearl
    Aug 2018
    NEPA
    Tires , tires , tires
    Just put the new Kanines on all around and vibrations are basically gone .
    And yes originals were oems and balanced .
    And yes Baja ron sway bar ,centronics wheel balancers ,stage 4 elkas ,upgraded tensioner were all
    installed each helped a little bit but tires were the biggest improvement .
    At 70 b4 was a pita to ride on hwy
    now a 100 is a breeze when necessary
    Durham,Maine
    Quote Originally Posted by strykerAKAmack View Post
    Now you've let all the horse out of the barn!!! They will know all the secrets!!!
    2012 RTL , Pearl
    "vibration at 70"
    I'm only 69... I'll have to wait a few months to see if I get a vibration at 70...
    If I do, I don't think a belt dampener or Kanines are going to help much...
    Nov 2013
    Oro Valley Arizona
    I have a lot of vibrations at 80. Unfortunately none of these are coming from the Spyder. Not too unusual to have a slight harmonic at a certain speed. This will vary and usually comes from the belt or cupping from the front tires.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
