2020 RTL CRUISE CONTROL ICON LOCATION ON DASH DISPLAY? Mine not showing up
Merry Xmas,
So went out for a ride today and had the cruise control on and did not see any type of a icon on the display. So when I got home I looked at the manual and it does say that there is a Icon for that on the dash/display but does not say its location.
I started the bike and turned the cruise on and off and saw nothing, next I tried toggling through the various settings while switching it on and off and still no Icon?
The cruise control does work as it should but at a loss where the Icon should be located on the display and if I should have it set to a certain position?
Any ideas?
Reason: Removed Prefix - not engine/size related! :-/
Originally Posted by Escorial
Merry Xmas,
Any ideas?
When you were “checking” at home, were you simply trying everything while sitting in your garage, Escorial? Because it won’t show until you are moving above 25mph. Page 32 of your Operators Guide will show you what the symbol looks like, and it is only displayed in grey, so it’s a bit hard to see. I believe it appears in the bottom left of the left lateral display. I never look at that. If I have turned cc on by sliding the button to the right, it exposes “on” lettering on the switch. That’s the quickest and easiest way to see if cc is actually “on”
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
When I was out of was sunny and I had sun glasses on so I bet that was the issue.
I was parked in the garage when I tried it out.
Cheers
Cheers
Yep, highly likely your sunglasses would have made it hard to see……just use your switch to check status.
HeliBars Handlebars
Kenda Kanine rear.
I don't think the cruise control icon lights up until you actually engage the cruise control (set a speed). Try that.
Yeah, I think that is how it works too, Monk. The symbol is pretty faint though, so it would be easy to overlook if wearing sunglasses, even if it is on.
HeliBars Handlebars
Kenda Kanine rear.
