Results 1 to 13 of 13
    Member jwt1959's Avatar
    Aug 2017
    South Central PA
    Default Another BRP Connect Problem
    Whenever I get a phone call, using an iPhone 10, and cancel it, my music from the iPhone is lost. I need to shut the bike off to allow it to reset and restart. Anyone else see this problem or have a solution?
    Active Member kissfan's Avatar
    May 2019
    Brooker, FL
    Completely lost?
    BRPC has some quirks about music.
    You can't select anything unless you're stopped.
    Sometimes it won't paint the Artists... you have to try it several times before they show up.
    Can you describe your situation? I have yet to receive a phone call while riding, so I haven't experienced what you are.
    My vice is passion for KISS.
    Oh, and food.
    Current ride: 2019 Spyder RT-L in Phoenix Orange.
    2019 RT-L , Phoenix Metallic Orange
    Aug 2017
    South Central PA
    Kissfan, I will be riding along and a phone call comes in. That causes the music to pause until I satisfy the phone call. I decline the call, and I would expect the music to start to play again. But it doesn’t. I’ve tried going into BRP connect on the bike and choosing the music app but do not get any of the options (I.e. playlist, artist, etc...) to show on the screen. I have also tried closing the app on the phone and restarting it. All my maps work, but no music. The only way I am able to get my music back it to shut down the bike, wait until everything is off and then restart the bike.
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Broken
    Radio
    Program
    Connection
    At least it’s an appropriate acronym....
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    May 2019
    Brooker, FL
    When this happens, pull to the side and come to a stop. See if you can get to your music then. You can't really access it while moving.
    Oh, and food.
    Durham,Maine
    Sounds like you should pull over beside the road, pull out a side arm and put it out of it's misery!! Some times after reading some of this I am glad I drive old iron!!!
    2012 RTL , Pearl
    Aug 2017
    South Central PA
    Quote Originally Posted by kissfan View Post
    I tried that. Also tried unplugging the phone and reconnecting. No help. Ran a test today using my wife’s phone to call mine. If I connect my music through Bluetooth everything works fine, as soon as I connect hardwire through BRP Connect I still have the problem.
    Aug 2017
    South Central PA
    We’re not quite there yet. But maybe soon!
    Nov 2017
    Southern MN
    not sure if this will help on iphone, but on my previous '18 and now my '21... while i am listening to dash music.. and it stops and I try to start it up again, I have to go to sygic maps and bring that up which then allows the music to play.. strange quirks.. and of course I have the older fobo caps, but they don't work on the original app, they work on fobo2.. which is not a choice for connect..ho hum..
    Rick..
    2018 RT-LTD , BLUE
    Aug 2013
    SF Bay Area
    Make sure your headset is only paired to the bike and not also to the phone. Remove headset pairing from phone.
    2021 F3 Ltd , Magna Red
    Aug 2017
    South Central PA
    It is only paired with my bike.
    Aug 2013
    SF Bay Area
    The phone OS is up to date? The dash version is either 20.8 for 2018/19's or 30.4?(I think) for the 2020's? Otherwise I don't know as it's never happened to me.
    Aug 2017
    South Central PA
    Both are up to date on software versions. My phone is at 13.7 and BRP is 30.7
