Results 1 to 12 of 12
    Aug 2008
    Maryland
    Default 2020 Spyder RT no auxiliary power
    accessories and running lights fuses checked good
    Any ideas - anyone know if bike has any accessories standard that run off of aux power?
    does the BRP phone usb run off aux power?
    Steve
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Aug 2008
    Maryland
    USB power is good from BRP connect - charges my phone
    No power at auxiliary light (bottom front of Bike) connector?????
    I know go to dealer - maybe we can find culprit!
    Aug 2008
    Maryland
    Figured it out no headlights - going to order some relays - hopefully that is all - stupid is as stupid does
    Aug 2008
    Maryland
    Installed two new headlight relays - still no headlights
    Called dealer for appointment
    Checked everything again before leaving (1+ hour ride) and saw for first time 7.5 amp headlights fuse - yes blown - replaced - life is good again we have lights
    Durham,Maine
    Darn you got that one by yourself!!!
    2012 RTL , Pearl
    Sep 2018
    greensburg,pa
    So what really happened? The whole story please.
    2018 RT-L , Blue
    Aug 2008
    Maryland
    Quote Originally Posted by bluewoo View Post
    I was hoping to avoid that -
    so I was hooking up the aux power for aftermarket light (lower front on 2020 rt) and decided to volt meter the the wires first since sometimes they are reversed and I slipped with probes and shorted the wires together.
    no sparks or heat in wires - so I probed again and 0 volts.
    So I started checking the rest of the RT - running lights ok, bike started - oops no headlights - in another thread I found out I blew headlight 7.5Amp fuse
    So now we also know that the headlights power and aux power share same fuse.
    Sep 2018
    greensburg,pa
    Thanks, Im taking down notes so I can be careful too.
    I'm having a hard time keeping up with you on your new ride and all these post!
    2018 RT-L , Blue
    Aug 2008
    Maryland
    I'm having a hard time keeping up with you on you new ride!
    My new ride continues to be a challenge - need to move fast - winter is coming - hopefully I won't have to get rid of it next spring.
    I enjoy modding and want to learn the RT - first time I've hosed up an install/mod - hope others can learn from my careless mistakes.
    Both my 2008 RS and 2015 F3 were so much easier to work on and access things
    RT panels are huge and require pushing and pulling to snap off in different places - not a comfortable 1st time experience. Bring back the many screws with rubber washers - unscrew lift off small panels - simple.
    Aug 2008
    Maryland
    Well finally - I properly installed the aftermarket bottom of front bumper led light ($24 because they only come 2 to an order, so technically $12) - fits tight and works great - super light.
    So, when you start bike the light comes on and when you turn off the bike it is a delayed turn off with headlights. That lower light will light up the ground in front of you.
    Durham,Maine
    2012 RTL , Pearl
    Aug 2008
    Maryland
    Thank you - it was quite the adventure
