Results 1 to 7 of 7
    Aug 2016
    Cleveland, Ga
    Default How can I remove a small stick on Mirror from my stock mirror?
    I put these small stick on mirrors on and now one is broke. What is the best way to remove them without harming the stock mirrors?
    Sep 2018
    Orillia Ontario
    Try using fishing line.
    2019 F3S , Blue
    Jul 2020
    NE Oklahoma
    Dental floss. Pull it back and forth through the adhesive and it will cut through it. Goo-Gone will remove the residual adhesive from the mirror.
    Kid Doc
    2019 F3-T
    All states and provinces visited solo on 2 wheels since 2006!
    Dental floss will also work. You can remove the mirror, lay it horizontal and put a little Goo Gone on the main mirror, Let it soak in and be patient as you work the line or floss between the two.
    Sep 2014
    USA
    Use a hair dryer and and a plastic prier to gently remove without scratching the glass.
    Feb 2020
    Sheridan, Wyoming USA
    Without knowing what kind of adhesive tape is on it, either a plastic scraper (if the tape does NOT have foam) and heat, or floss/fishing line (if it DOES have foam) will work to get it off. And if you do not have Goo Gone, WD-40 works very well for removing adhesive residue...and most households have that on hand.
    Sep 2018
    greensburg,pa
    Goe gone
    2018 RT-L , Blue
