Results 1 to 6 of 6
    Active Member Eugene's Avatar
    Apr 2017
    Hamilton, Ontario, Canada
    Default 2013 RT Ltd Hiccups - need input please
    Greetings everyone - hope you are all enjoying some riding. My 2013 RT Ltd has a problem - on occasion, when started, it idles sporadically, the revs go up and down on its own. If I put it in 1st gear, it clunks into gear and continues clunking rapidly - it does move forward but the clunking is terrible and does not quit. The check engine warning comes on. After shutting it off and starting again 3 or 4 times, the idling is back to normal and all is well, This happens about every 5th or 6th start. Needless to say, it never does this at the dealer!!!!!
    Any thoughts? It doesn't seem to matter if the engine is warm or cold.
    Thanks for any input.
    Sep 2012
    Stetson, Maine
    Check vacuum lines, check purge valve, plugs and plug wires. Do you have a good dealer nearby.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Sep 2017
    Durham,Maine
    What he said!!!
    2012 RTL , Pearl
    Apr 2017
    Thanks - yes, my dealer is pretty good - will ask them to check
    Sep 2017
    Durham,Maine
    You could save yourself some money if you took a look at the vacuum yourself! just a thought If you work on your own stuff and have the tools!
    2012 RTL , Pearl
    Apr 2017
    Thanks Mikey - that would be a complete disaster!!!
