Ryker Axle Plugs
After reading complaints from Ryker owners about the axles rusting if you look at them wrong, and after seeing the post here about the axle/hub caps from Adept Powersports, since mine were missing too I went ahead and ordered the inside caps as others have. After receiving them and putting them on, I started thinking about the open outside axles and started looking for axle plugs to plug the unsightly holes and to help protect the inside axles from rain.
I found that a guy on FB had posted about these black plugs from Amazon, so I ordered them (4 pack for $8.00). They fit nice and snug and IMHO they give the wheels a nice finished look, they should also help keep the inside dry. I thought I'd post about them here, just in case someone wanted to order the plugs. If yours is already rusted, at least the plugs would cover it up.
2020 Can Am Ryker Rally Sport Touring Edition
you would think they would come that way, but they would want another $1000 for them!!! Gives it a nice finished look!!!
what was the part number for these? I think I will get a pair. I'm going to get some enamel and paint the inside of the axles first though.
Here you go, got them on Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I put them on all three wheels.
Do the Amazon caps work in the inside and outside?
I dont know, I didnt try because I ordered and installed the OEM axle/hub caps on the inside before I found these for the outside.
Thanks for posting these on Youtube RykerRick i seen and ordered the other day!
I used the 1 3/4 vs 1 1/2 inch plugs for the inside of the wheels. A bit of a tight fit but they worked just fine.
