Results 1 to 12 of 12
    Mar 2020
    SE Wisconsin
    Default Can someone show pics of Jacking / lifting points?
    Can someone show pictures of the lift / jacking points on the newer (2019ish) Spyder RT
    I have a auto floor Jack and don't have ATV Jack.
    Also where to put the Jack stands
    Thank you!
    Jan 2015
    southern WI
    A arms in front, and rear lower shock mount for the rear work well. If you get a bike lift, the frame makes a "T" underneath that makes a good lifting point.
    2016 RTS , Pearl White
    Feb 2016
    The service manual states to never lift by the rear shock bolt; lift by the frame only.
    2020 RT Limited , Marsala Red
    Mazo specifically said the rear shock mount. I have a specifically marked piece of 2x4 for lifting using the mount. If one lifts using the shock and thereby the shock bolt as the lift point one can bend the shock bolt making it a devil to remove. There s history on this topic in SL.
    Mar 2020
    SE Wisconsin
    Well, I got it up enough to get the car dollies under the tires20201114_174205.jpg
    Sorry about the pic
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Default To lift a spyder
    I Kbaldwin
    I check my brakes, and change the oil as in the pictures, I made three wooden blocks, I use my car ramps to mount the front, for my rear jack that I press on the shock absorber.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Feb 2016
    Shock bolt or shock mount still isn't the frame. The manufacturer has always stated to lift by the frame only.
    Oct 2020
    Arizona
    See if this rights it.
    INDIANA, USA
    Default Pictures
    YES, the picture is correct. ......
    ENJOY YOUR LIFE WITH A SPYDER
    Florida Swamp
    Put some pieces of board or some blocks on the jack if it does not contact the correct lift points.
    2019 F3-S , Black & Silver
    Jan 2019
    Hunter Valley NSW Australia
    Quote Originally Posted by Kbaldwin View Post
    Sorry about the pic
    You in Australia Kbaldwin, it displays ok down here in the land down under
    2017 RTL
    2017 RTL , White
    Dec 2018
    Long Island
    Go to you tube and search for jack points for can am spyder. You'll get a ton of videos.
