Results 1 to 9 of 9
    Active Member Myersd802003's Avatar
    Feb 2016
    Alamogordo, NM
    Question Battery Tender installation on F3
    Newbie Question. Tomorrow, I'm going to install the Battery Tender plug on to the battery. If I unplug the battery, install to the post and plug the battery back up. Is there anything else needed to do? I don't want the nanny to go all crazy on me or the F3. Will it be okay? Thank you.
    2012 RSS (Wife's)
    2015 F3S (Mine)
    Apr 2012
    Northglenn Colorado
    I don’t remember if I actually "unpluged" it. I think I slipped the battery tender connections on top so I did not completely disengage the battery. I also just fed the battery tender out the back of the frunk and zip tied the connector to the frame. I also use one of these so I can get power to my phone or GPS. I feed the usb cable up through the steering wheel to power the devices. I disconnect when I want to charge the spyder battery using the battery tender. So I use the battery tender cable for a dual purpose. It is fast and cheap solution
    Feb 2016
    Alamogordo, NM
    Default Battery Tender
    Are there screws that attach to the battery connection to the post? I hope my cord is long enough to go to the handlebars. The service department said the cord wouldn't be long enough, but I think it is.
    2012 RSS (Wife's)
    2015 F3S (Mine)
    Apr 2012
    Northglenn Colorado
    the USB converter is just that. You can attach a phone usb charging cable to the other end of the converter. My phone charger cable was just long enough but I think you can purchase longer ones.
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    There are screws and I unplugged the whole battery to do that.... I recently installed Lamont's power outlet for the f3 directly to the battery and now use that for the tender... Like it better and I can charge my phones with it as well.
    Live, Love, and Ride! God Bless!
    Active Member Sccar's Avatar
    Mar 2015
    East Texas
    No issue with disconnecting the battery. You will have to reset the clock.
    I placed mine in the frunk. Originally installed it next to the left shock but decided to move it inside the frunk.
    2015 F3S SE6
    You don't stop riding because you get old, you get old because you stop riding
    2015 F3s , Orange/black
    Default ANNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNND
    I strongly advise putting on STAR washers ( the type with the teeth inside the ring )on the battery bolts.......they will never loosen by them selves .........NOT EVER...............and this is something that happens to many and causes a lot of problems that could have been avoided....JMHO.....Mike
    Aug 2020
    Ontario
    Default Clips or rings?
    Do you attach your battery tender to your battery with alligator clips, or ring attachments?
    (see attached)
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by FragTagger View Post
    (see attached)
    Old post, but, certainly use the ring attachments with a star locking washer.
    2022 RT Sea To Sky
Tags for this Thread
