Page 3 of 3 FirstFirst 123
Results 51 to 63 of 63
  1. #51
    Sep 2014
    USA
    CRANKSHAFT POSITION SENSOR (CPS) CPS Location The CPS is located on the lower engine crankcase half, on the LH side of the engine.
  2. #52
    Very Active Member mastertek2000's Avatar
    Mar 2012
    E Freetown MA
    Do you mean left sitting on it or looking at is
  3. #53
    Sep 2014
    USA
    Quote Originally Posted by mastertek2000 View Post
    Correct left side sitting. From the picture in the manual it looks to be under the engine about the middle of where you see the side of the engine. Lower crankcase half.
  4. #54
    Mar 2012
    E Freetown MA
    Ok found it located at the bottom of the crank what’s should the homs be if you Homs it if it like all other CPS air should be 550-750 Homs
  5. #55
    SoFlo
    FWIW, and I may be wrong, that sensor is likely a Hall Effect or similar sensor. Been dealing with similar on another project. A friend that designed electronic ignitions for race engines explained those type sensors 99.99999% of the time either work fine or fail. He also explained that in hundreds he sold on the race ignitions, only 1 failed intermittently and required troubleshooting with a heat gun to induce the failure.
    My advice, and others here had them fail also, just replace it, they have the track record to indicate very likely the problem.
  6. #56
    Sep 2014
    USA
    Ohms-
    Make sure sensor connector is fully inserted. Measure resistance from connector: ECMA-H1 to CPS-1 (expected value: < 2 ohms). Measure resistance from connector: ECMA-K2 to CPS-2 (expected value: < 2 ohms).
    I have heard of the camshaft sensor failing dont think I have heard of a crankshaft sensor failing.
    But its possible.
  7. #57
    Mar 2012
    E Freetown MA
    I did a shearch on this site and seen a few 2014 having them replace thanks for the info
  8. #58
    Mar 2012
    E Freetown MA
    Ok well got new crank sensor in and it tested just like the old on .985 ohms so I did not install it ended up ready the bike apart some more and said what the heck check plugs installed new plugs she fired up runs like a charm thank you all for the help
  9. #59
    Sep 2017
    Durham,Maine
    Good for you!!!!!!! Change the wires while you were there??? Glad you got it!!!
    2012 RTL , Pearl
  10. #60
    Sep 2014
    USA
    Just wondering how did the spark plugs look and only 10k miles? The plugs were bad?
  11. #61
    Jul 2014
    Mint Hill, NC
    No wires on a 1330; individual coils on each plug. Another advantage over the V-twins.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
  12. #62
    Mar 2012
    E Freetown MA
    looked good just gas fouled
  13. #63
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    so it was gas the whole time after all? I replaced mine at 25k on my 2014 just for grins they still looked good but I had stuff off it already while I was doing my shock adjusters and sway bar. There's new gas stations here in Austin called QPS and they sell ethanol free gas but only regular, I had my chip flashed so Im stuck with premium only they say. Will we ever get off ethanol? Glad you got it running.
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
