Results 1 to 11 of 11
    Mar 2020
    Cape Coral, FL
    Default Error code p0172 after stage 2 flash
    Anybody have any error codes pop after stage 2 flash?. I have a 2018 F3s. Did stage 2 flash, cat delete, and K&N air filter. After about a week, check engine light came on and shows code p0172. Any help would be greatly appreciated.
    Mar 2013
    Marion, Arkansas
    PO172 ECM System too rich Bank 1
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Aug 2019
    Stoughton, WI
    P0172 Possible Causes
    What does this mean?
    Faulty Front Heated Oxygen Sensor
    Faulty Spark Plugs
    Faulty Mass Air Flow (MAF) sensor
    Exhaust Gas Leaks
    Ignition Misfiring
    Incorrect Fuel Pressure
    Faulty Fuel Injectors
    I'm guessing Monster/Wick-It is going to have to scan/reflash your ECU. Dealer won't help with your flash. Kind of a PIA Good luck
    2022 RT Sea To Sky
    Mar 2020
    Cape Coral, FL
    Going to try replacing o2 sensor. Will post if it works.
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    Quote Originally Posted by jjpgator View Post
    Question...do you use premium gasoline..or regular.
    Mar 2020
    Cape Coral, FL
    Yes. Have tried regular and still having the problem
    Sep 2014
    USA
    Contact whoever has done your ECU flash and see what they say.
    Aug 2019
    Stoughton, WI
    It's been 12 days. You have contacted the the place that did the flash, haven't you ??
    2022 RT Sea To Sky
    Mar 2020
    Cape Coral, FL
    Yes. I have sent 2 emails and no response. I put the cat back on and changed the O2 sensor. After about 2 weeks the check engine light went off.
    Aug 2019
    Stoughton, WI
    Who did the Stage 2 flash ?
    2022 RT Sea To Sky
    Mar 2020
    Cape Coral, FL
    Wick-it
