Results 1 to 16 of 16
    Central Oklahoma
    Default 2020 RTL - broken saddlebag latch
    Any suggestions on how I get the right side bag to open? Dealer has the parts on order, but considering the last time they ordered warranty parts took 2 months for the parts to arrive... I wanted to be able to get into the saddlebag now.
    2020 RT Limited , Petrol Metallic Dark
    Jul 2010
    Las Vegas, NV
    No problem. Look up under the front of the saddlebag. You will see a cable. Follow it to the adjuster. Turn the adjuster until the latch opens. Then return it to the original position. Call me if you need help. Joe
    Joe Meyer
    Jul 2021
    Virginia
    The adjuster, can I twist this with my hand or do I need a wrench?
    Aug 2020
    Georgia
    What did you wind up doing with your latch?
    Mine just broke at the hinge.
    Haven't tried to get it open yet, just curious what you did to fix it. Did you have to buy a completely new latch or were you able to just by the plastic lever?
    Sold: 2020RT base with numerous improvements and farkles
    Previous 2 wheels: 3 BMWs, 1 Honda, 1 Yamaha and 1 Husqvarna
    Katy, Texas
    Quote Originally Posted by sduskin View Post
    It's explained how to get into the saddlebags in the owners manual. Remove rear seat then remove 2 screws on the cover over the saddlebags, then you can trip/unlatch the door.
    Central Oklahoma
    Quote Originally Posted by WilcoJunoHotel View Post
    The dealer replaced both latches under as under warranty. After they were done, I adjusted the cable tension per the kind reply on how to get my saddlebags open.
    No issues since.
    Mar 2016
    New Hampshire
    Hi. I had the same problem in the fall. The latch mechanism didn't work, part of it was broken. In October, part only took a few days to get.
    Sometimes it only needs adjustment. Found someone who said it isn't greased.
    I don't know where you are from, but i took it to the dealer in rutland Vermont. They were great. My local dealer was going to make me drop it off, maybe they would get to it in a few weeks. Didn't care we might have snow, and i don't have a trailer. Rutland was great. Popped it open for me so i could get my clothes out. Ordered part. I came back with bike when part came in, and they did it right then while we'r went to breakfast. Didn't have to leave it.
    Quote Originally Posted by Glorie View Post
    .... I have had better results in Rutland than in Colchester or Derby VT..... they are the other twpo dealers that I know of ..... Mike
    Aug 2020
    Georgia
    Same here but I don't have a good dealer anywhere close like you. So I ordered the mechanism and will change it myself because, like your experience, my local dealers want me to leave my Spyder with them while they order the part, wait for the part and then schedule the repair (3-4 weeks). For the $50 so bucks it will cost me, I will fix it myself.
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Quote Originally Posted by Rider Steve View Post
    I just learned this is actually in the manual! Unfortunately ... guess where my bike is ... and why .... Yup!
    At least the real season hasn't started yet.
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    May 2020
    Rhode Island
    How difficult is the fix? and where did you get the latches?
    Curious ... just for next time!
    Aug 2020
    Georgia
    Quote Originally Posted by Mike0123 View Post
    I don't know yet - part should be here late next week. I will try to remember to post back what is entailed.
    No dealer south of VA had one in stock and I have had good luck dealing with Sierra Cycles in AZ so I ordered it from them and they will ship it to me here in GA.
    Each latch (left and right side - they are "handed") is $37.99 and you'll pay shipping unless you order it and pick it up from your local dealer.
    May 2020
    Rhode Island
    No issues since.
    Could you please reference the adjustment post if you can find it please?
    TIA
    Dec 2013
    ... I adjusted the cable tension per the kind reply on how to get my saddlebags open.
    No issues since.
    TIA
    It's detailed by cptjam in post #2 of this thread Mike - quoted below
    Quote Originally Posted by cptjam View Post
    Cheers
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    May 2020
    Rhode Island
    Cheers
    OK thanks. I saw that but I was looking for some type of procedure to get it adjusted to work smoothly ... maybe a tension setting, where to lube ... use a cable lube or not. This seems to be a fix if it doesnt open.
    Dec 2013
    That's what sduskin said in his post - the dealer replaced both latches, then after they were done, he adjusted the latches per cptjam's post.
