Results 1 to 11 of 11
    Active Member Sampi1099's Avatar
    May 2020
    Apache Junction Az
    Default What is idle rpm meant to be????
    Can someone tell me what the idle rpm of a 998cc motor should be. I have a 2012 Can am Spyder RT Limited SE5 with the 998cc motor and it idles at 1300 to 1400 rpms. Is this to high and maybe a vacuum leak?
    Jim
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    thats correct mine is the same
    Nov 2018
    Waynesboro, PA
    That is right where it should be 1300 rpm. and you should shift at about 4500 to 5000 rpm
    My Spyder
    2012 RTL , Brown
    May 2020
    Apache Junction Az
    Quote Originally Posted by CopperSpyder View Post
    Thank you sir and yes i shift about 4500 to 5000 rpm with my reflash of my ecu.
    May 2020
    Apache Junction Az
    Quote Originally Posted by Gordy View Post
    thank you sir.
    Yes on the idle. I recommend trying 5500 as your shifting point as well as running range.
    The 998 was originally designed for a European crotch rocket. It is designed to rev. It doesn't really start making HP until around 5,500 RPM. If you don't rev it up, you can end up with issues over time.
    Active Member vindex1963's Avatar
    Jul 2018
    Payson AZ
    My 2012 had idle issues, it was the vacuum lines on the throttle bodies that had cracked.
    2012 RT A&C SE5
    2015 Victory Cross Country (Dyno tuned 118hp 116tq)
    2006 Triumph Rocket Dyno tuned 140hp 154tq)
    May 2020
    Apache Junction Az
    Ron i don't think rev it up will be a problem since i run on the interstates most of the time and the rev's are up there. but thank you
    Feb 2012
    Spring City,Utah
    Agree with Ron. I shift at 6000- to 7000 and cruise at 5000. The problem you will encounter is that the clutch doesn't fully engage until around 4000. Below that you run the risk of the clutch slipping and have premature wear on the clutch plates.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2018
    Bristol
    Had my 2011 3-1/2 years, was told 1300/1400 rpm was normal, anything over that TPI ISSUES.
