Results 1 to 10 of 10
    Aug 2019
    Stoughton, WI
    Default Adding lights to the rear of F3's
    Saw a thread regarding additional lighting to the rear of RT's. Wanting to be better seen, I did $6.50 worth of added lighting to the back of my F3S. For $5, I added some red LED strip lighting to my inner rear fenders. I connected them to the accessory lead under the passenger seat. I also spent a $1.50 on a red LED light that I double side taped to the top of my license plate light. I just routed a thin wire to the license plate light base. On the more $$ toute, I added a TRicLED run/turn/brake light light in early spring. I bought that last Black Friday from TricLED for $65. Hopefully traffic from behind will be looking ...
    2022 RT Sea To Sky
    SoFlo
    Boy did I get that title wrong. I was expecting a big smokey tire shredding burnout...
    Active Member ChicagoSpyder's Avatar
    Chicago
    Same here LOL
    2018 F3 Limited , Black/Chrome
    Did similar. Had Spyderpops deck out my rear trunk, vents, and mirrors. You got the better price though.
    Aug 2019
    Stoughton, WI
    $5/lights, $4 t-taps and a couple hours of putzing. I tapped them into the license plate lamp. Should be noticeable come darkness...
    2022 RT Sea To Sky
    Sep 2020
    Ontario, Canada
    Do you have an after sunset photo to show us?
    Aug 2019
    Stoughton, WI
    I'll try and get one tonight ..
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    A couple from the back and one from the front..
    2022 RT Sea To Sky
    Jul 2020
    Isanti, MN
    Can I ask where you got the strip LEDs
    Aug 2019
    Stoughton, WI
    2022 RT Sea To Sky
