Results 1 to 20 of 20
    Mar 2013
    Taylor, MI
    Default Lightning up the back end
    Looking for some help. I am looking to add some brake lights to my 2020 RTL. What I would like to get is a light that will flash when it senses deceleration. I had a Volvo light on my BMW that was installed by the former owner so I have no idea how it was installed.
    I looked at Volo’s website but it just said to tap into brake light circuit. Will this work on the Can Am without screwing up the stock brake lighting? I think it might work ok, I just need someone to back me up.
    Any other ideas will greatly appreciated.
    Thanks, Dale.
    Life is too short to drink cheap beer.
    Aug 2019
    Stoughton, WI
    I had a Volo light license plate frame/light on a couple past bikes. You simply tapped into the license plate light. Not sure how the newer ones work?
    2022 RT Sea To Sky
    Mar 2013
    Taylor, MI
    Think I’ll just go for it. I’m worried about the canbus system might think there’s a problem and start throwing errors. Waiting for my trailer hitch and wiring harness to come in, I’ll ask the tech what he thinks.
    Mar 2020
    North Carolina, Fayettville
    check with the u-tuber Smoaksvlog his website is http://www.shawnsmoak.com
    Aug 2008
    Maryland
    U might want to check out STS smart brake Module and Gear brake module. One of these modules (I forget which) is a simple plug and play install for some Spyders and all Rykers.
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Jun 2016
    Harrington, Australia
    Ouch.......I read that headline and thought “that must have been painful”, Doc45. Can you sit down yet ?
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Dec 2013
    Pete
    I had zachery the same thought!! You'd get a real charge in the seat of your pants outta something like that.. Probly put a real sparkle in your eye, too... & make your hair wanta stand on end.... the other end, silly!
    Must be an Aussie thing.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Idaho
    Quote Originally Posted by Doc45 View Post
    Unless there has been a change in the 2020s vs earlier models, there is no connection between the brake lights and the CANbus.
    2014 Copper RTS
    Aug 2019
    southwest oHIo
    Ouch.......I read that headline and thought “that must have been painful”, ...
    I had zachery the same thought!! You'd get a real charge in the seat of your pants outta something like that. ...
    Yeah, I saw the headline and wondered if it was one letter short or if there was an extra one.
    Missing a letter: "lightEning" up the rear end, I was wondering how much weight he wanted to remove.
    Extra letter: "lighting" up the rear end, made a bit more sense, and turns out that's the way it went.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Mar 2013
    Taylor, MI
    I would like to thank everyone for their concerns over the condition of my “rear end”. Everything is as it should be.
    Now back to the bike, I don’t think the Volo light will fit. Not enough room at the top. Guess I will look for some other means of “lightning up my rear end”, pun intended. Thanks for the heads up on the STS Smart Brake, I’ll look into that.
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Aug 2008
    Maryland
    Quote Originally Posted by bluewoo View Post
    I think he is looking for one that acts on its own via deceleration , such as throttling back, or downshifting and engine braking
    Sep 2018
    greensburg,pa
    Quote Originally Posted by BeRight View Post
    Oh , Ok sorry!
    I can only find YELLOW strobe warning lights
    https://www.amazon.com/StrobeWise-De...ct_top?ie=UTF8
    2018 RT-L , Blue
    Mar 2013
    Taylor, MI
    Yeah, I’m looking for a light that has a deceleration light. If I can’t find something, I’ll just light up the rear end as much as I can.
    Aug 2008
    Maryland
    Via google searching
    1. ADMORE LIGHT BAR WITH SMART BRAKE TECHNOLOGY https://admorelighting.com/product/a...ration-safety/ $199.00 – $239.00
    2. Smart Brake System https://motorbikewriter.com/brake-light-save-life/
    $125.00
    SMART BRAKE MODULE
    Don’t become a statistic of tailgating drivers. This Smart Brake Module activates your brake brake light even when you slow down on the throttle, not the brake.
    It warns tailgating drivers behind you to back off. It could just save your life!
    You can choose between 2 options for the operation of the Smart Brake Module – FLASHING and STEADY mode.
    Suits all model of motorcycle and light, and is approved for use worldwide.
    Smart Brake System quantity
    3. Amazon
    Motorcycle Brake Light Flashing Deceleration Warning 20W-S 2 pak, Direct Replacement for OEM 1156 Bulb, USA & CA legal tailBlazer by Kisan
    Visit the KISAN ELECTRONICS Store
    Price: $109.95
    May 2018
    Bristol
    You might want to check with Spyderpops.com. It doesn’t work on speed reducing though. It a run, brake, turn, strobe set up , 255 LEDs, 127 when turning. Really lites up the rear of my 2011 RTS SE5 . Great effect. It’s a plug& play for $119
    Jul 2018
    Saskatchewan
    Get this one. https://www.skenelights.com/new-p3-with-decelerometer .....excuse the bad video...1080p doesn’t do it justice and no decel but it works great on the quick to slowdown without brakes transmissions on RTs..
    Cant seem to upload video I took in garage due to compression size
    Aug 2008
    Maryland
    Here's one that goes on the back of your helmet - good reviews
    https://www.brakefreetech.com
    Aug 2008
    Maryland
    Seems these work - just wire to brake lights $70 https://ozrobotics.com/shop/smart-br...ght-modulator/
    Smart Brake Module – Smart Brake Light, Brake Light Modulator
    I drank the kool aid and have ordered one. I have looked at this a couple times, but it was not available for sale at that time. Read the reviews, saw the pictures, and like what I saw. Price is $169.95 and they are charging me $10.00 shipping for one. If I like, I will order another for Linda. Stay tuned for a review once I get it. They say 3-5 business days to ship.
