Čheck out cheap cycle parts dot com for a parts fiche that will tell you what you need to know then go to an hardware store and get them
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
I did but need to confirm. It doesn't show the bolts with the assembly -
First fitch STEERING shows nothing https://www.cheapcycleparts.com/oemp...dd0df/steering
Second fitch ELECTRICAL ACCESSORIES shows assemblies but no screws???? https://www.cheapcycleparts.com/oemp...al-accessories
Ill just get a couple lengths.
Take another out and match it at a Home Depot or Lowes?
That's what I will have to do....God forbid I lose another one LOL!
No problem, it should go only from the opposite side assembly to your pocket. Be sure you have no holes in the pocket.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Ill wrap it in a piece of duct tape that way I cant lose it.
2014 Copper RTS
Tape it to your leg and buy four!!
You can saw the longer screws off with a hacksaw and dress the ends a bit with a 3 square file and they will work just as well as purchasing the shorter screws.
Originally Posted by bluewoo
Trading in the 2018 and I cannot find the two factory m4 screws I removed to install a cup holder. Yet I found the ones for the 2006 Goldwing
What is the exact size?
Thank you!!!!
Ace Hardware if you have one close to you. Much easier to get automotive type screws there in the length you need in a small quantity. Don't put wood screw crap from HD and Lowe's in your Spyder. I'm like you and magically disappear screws..put it in a paper towel, tape it up and buy spares lol..
M4-.70 x 12 is the size! Ace hardware has them $3.29 each!!! But I am a rewards member so i used my $5.00 coupon!!!!!
These work perfect too for shortening little bolts and screws.
That's what I use. I also replaced the BRP rusty screws in my 2014 RT with ss screws from Ace. Got tired of seeing those rusty heads in my controls.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
