2020 rt limited self leveling suspension adjustment
when i first got it , it wasn't installed. now it seems to be disconnected and i have a very BUMPY RIDE. Any suggestions on reinstall?
I think you got to give us a little help with better info!! Read what you wrote!
The dealer should have connected the lever
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
1. Was it installed by the dealer or someone else?
2. Did it ever work?
3. Is it a BRP air system or some after market rig?
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
It did work. Dealer installed
Warranty work; take it to the dealer.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
any idea how to reconnect? thank you
Not sure about the 2020 but they use to be mounted to the swing arm to a switch same side as the belt
There are several reasons it may not work. Here are done options:
1. Get the dealer to fix it.
2. Get a shop manual and troubleshoot it yourself.
3. Get on YouTube and search for: Can Am Spyder Compressor. There are several videos on the subject.
1998 Honda Valkyrie
US Navy Veteran
There's a tab on the swing arm that's suppose to have a threaded nut attached to it, that's where the arms suppose to be attached. If the 6mm nuts still there get a 6mmx 20 mm bolt and put it back, maybe a small drop of blue Loctite would be nice also!! Good luck!!
