Results 1 to 21 of 21
    Invalid Emails
    Aug 2019
    Elizabeth City NC
    Default Magic Mirrors - which ones to use?
    I want to install the Magic mirrors I see there are different companies selling them is there a preference as to which one to use.
    Last edited by Peter Aawen; 08-24-2020 at 07:01 AM. Reason: This is a 'How Do I?: Not a 'HowTo:' DIY description.
    Durham,Maine
    I would go to Lamonster Garage
    2012 RTL , Pearl
    Feb 2020
    N. Wilkesboro, NC
    Definitely LaMonsters version. The Slingmods version has larger magnets meaning you have to eliminate one of the body bolts. Not a big fan of that. LaMonsters version keeps all OE body bolts. I have LaMonsters version and ride on some fairly rough roads from time to time. My mirrors haven't moved in 6 months.
    Active Member Air Force PAO's Avatar
    Jul 2011
    Kyle, TX
    Definitely LaMonster's. I recommend going with the "two per side" so you KNOW the mirror is secure on one factory post. They work great.
    John
    Test message.
    2016 Spyder RT
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    I like mine from LaMonster no problems at all
    Nov 2018
    Waynesboro, PA
    I have the LaMonster http://www.lamonstergarage.com/lamon...-am-spyder-rt/ There is two installation videos there too.
    My Spyder
    2012 RTL , Brown
    Mar 2015
    forrest above Reno, Nv
    I have the 3 magnet per side setup and didn't have to remove any OEM attachment screws. The MM's work GREAT.
    2014 RTS , Circuit Yellow
    May 2018
    Chateauguay, Qc, Canada
    If your handy DIY them. save $$$$$$$ for the gas you will use after you have them.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by Air Force PAO View Post
    John
    I think Lamont only sells the (3) per side version these days. They won't come loose. No need for the (2) magnet version, even if you can find them.
    Dec 2019
    Land of Lincoln
    I bought Slingmods. Install was easy. No body bolts were lost in the process.
    Aug 2020
    AB
    Do they work on the 2020 RTL?
    Quote Originally Posted by BuRPi View Post
    AFAIK, Nope! The 2020's & on apparently have mirror mounts sorta similar to the F3's!
    Apr 2016
    Chicago IL
    Monk, you are correct, they only sell the three per side. For added safety add a zip tie thru the wires on your turn signal wire harness coming out of the mirror at the connector that slides inside the panel and you will be a happy camper. My wife just went on a two thousand mile trip just after I put hers on and she was very pleased.
    Aug 2020
    AB
    I just learned from Lamonster that Magic Mirrors won't work on a 2020 RTL.
    Durham,Maine
    He dose have a fix for the wobbling mirrors on the 2020!
    2012 RTL , Pearl
    Mar 2015
    Fritch, Tx
    I put these small convex mirrors on my bikes and the Spyder. Properly adjusted, the combination of the main mirror, the convex, & your peripheral vision gives you 360° of vision without even turning your head. They only cover a portion of your main mirror where you typically see the sides of your body anyway. They cost about $6/pair most places.
    Those who say " I can't" will always be right.
    Member KVRB's Avatar
    May 2020
    Vero Beach, FL
    Just received an email from Lamonster stating he is working on a Magic Mirror fix for the 2020 Spyder and should be ready in a couple of weeks. Since the mirrors need to be removed often if you do your own work, I would prefer the magnetic fix over BRP's screw fix. Stay tuned!
    Aug 2020
    Shenandoah Valley
    Quote Originally Posted by KVRB View Post
    Hi KVRB, advanced apology for my novice question... I was to understand that the 2020 mirrors don't need to be often removed, like with prior year models...?
    I ask because I just had the dealer order the BRP bolt-on fix. Should I ditch BRP's solution and go with Lamont's?
    Thanks in advance,
    Truck
    Jul 2010
    Las Vegas, NV
    The mirrors do not need to be removed for routine maintenance, on the 2020. I like Lamont’s magic mirrors for the 2019 And older better than the rest. I have installed quite a few sets.
    We have a fix for the 2020 RT. Works great, much less expensive than BRP.
    Joe Meyer
    Aug 2020
    Shenandoah Valley
    Quote Originally Posted by cptjam View Post
    Thank ya Sir.
    I saw your post in another thread. Actually, I referenced you when talking with the dealer. I 'think' BRP is going to provide the fix for free. There was a BRP TB on the shaky mirrors. Seems it's prn... if one complains, BRP sends the fix.
    We shall see. If the dealer tries to invoice for the fix, I'll be a customer of yours instead.
    May 2020
    Vero Beach, FL
    Quote Originally Posted by Truckie View Post
    Thanks in advance,
    Truck
    Hi Truckle! I also am a novice and have not attempted any maintenance on my 2020 yet. I was referencing different videos I have been watching about 2019 & earlier models I have been watching for the last year. And thanks to cptjam for enlightening us.
