Are 2020 RT Passenger armrests vertically & horizontally adjustable?
BRP claims that these are both horizontally and vertically adjustable. OK, so they have two horizontal positions. But I can't see how they are vertically adjustable. Am I missing something?
I want to know also. I found a video for an F3 but shows them opening outward a little.
Looks like they may be able to bolt on more forward or back? They look slotted to me on the bottom mounts.
https://leadersrpmshop.com/can-am-sp...caApktEALw_wcB
https://www.youtube.com/watch?v=IJRH...ature=youtu.be
When you bolt them on, you have 2 different screw hole sets to use.
I would say the vertical adjustment is about 1" or so.
My wife wanted them on the higher side so adjusted them up by removing and using the other bolt holes.
Thanks!! The RT look different from the F3.
https://can-am.brp.com/on-road/us/en...-armrests.html
Thanks to TXGreatRide for posting these on another post!!!!!
https://instructions.brp.com/content...mber=219400958
I have the 2020 RTL, BRM passenger arm rests, they swing to the side, and not much, but enough for a careful passenger mount. I can tell you, they do not swing up out of the way as the earlier models.
