Results 1 to 6 of 6
    Apr 2016
    Florida
    Default F3t glovebox usb has no power
    Can I check somewhere to see if I need to plug in power? Thanks
    Jul 2011
    Mitchell, Ontario, Canada
    What year?
    2018 F3 LIMITED
    Apr 2016
    Florida
    I do have power to my iPhone on my 2016, but it will not power the garmin gsp
    Jul 2011
    It will depend on the Garmin model. Some will not work on a usb plug at all. Except in data mode, like when connected to a computer. May go into data mode on the Spyder since it is a data port. Only really works on the power adapters that come with it. Others will work with a usb power plug but only high power ones. Some motorcycle models need a 12V power source.
    I have not looked up the specs for a 2016. But the usb plug in your F3T is likely a usb 2 spec port. So only 500 ma of power and that may not be enough. Also it is a data port and the gps may get confused and go into data mode.
    You may need to install a power plug that will work with your Garmin.
    2018 F3 LIMITED
    Jun 2011
    Near Lexington, NC
    Will it recharge a cell phone or Sena radio? Have not yet tried to use mine but if I ever get to go on a trip, that's what I'd want it to do.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Apr 2016
    Florida
    I installed a garmin hard wired line from the accessory power supply under the left panel and it works only when engine running. Thanks
