Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Thread: Replacement Key
  1. #26
    See Post #6 for beveling the Ilco blank.
  2. #27
    Active Member Tec35's Avatar
    Dec 2019
    Rhode Island
    Compare the Ilco key with the original. I think you need to cut back the edge of the key at the top to allow it to push in deeper into the ignition switch. The Ilco should open the seat and frunk.
    Thank you! that is what it is the 2 notches at the top are not lining up in the same position as the other keys.
    2017 F3 limited , Black
  3. #28
    Dec 2019
    Rhode Island
    Yes, thank you, I saw your post and made sure they put the bevels in. However, I noticed on my Spyder Keys the bevels are much further up the shaft.
  4. #29
    I beveled the Ilco blank on my bench grinder after making rough estimate marks from the Spyder key; figured I could take a little off until I got adequate clearance in the ignition switch. If I recall correctly I think it took about three swipes through the grinder.
  5. #30
    Dec 2019
    Rhode Island
    That is a good idea I didn't even think about that. I will try that thanks again
  6. #31
    May 2021
    Florida
    Question
    you could also have DESS turned off and not worry about programming keys to the bike. The Ilco flat key will also start the bike. I keep an ilco spare in my billfold....just in case of a senior moment.
    How do you turn the DESS off?
  7. #32
    Northern Kalifornia
    Quote Originally Posted by Queenspirit View Post
    I think that has to be done by a dealer if they'll even do it?
  8. #33
    Jan 2021
    Monroe, la
    You can buy the BUDS software and the MEGATECH license good for a month or more depending on what you purchase. The you can turn off the DESS. Then after the MEGATECH expires buy the regular license for your model to continue in trouble shooting all the codes you get. I have save a lot of money not having to go to the dealership getting the 2010 RT running for my wife.
