Results 1 to 24 of 24
    Apr 2020
    Pennsylvania
    Default Bouncing Fuel needle on 2011 Spyder RT
    I have a 2011 Spyder Rt Limited and my fuel needle bounces alot. Suggestions?
    A common situation for 2010 and 2011 Spyders. Many have disconnected the analog fuel gauges and went to the digital ones that are built into the machine.
    Note: to make this fix work, you need to disconnect both the fuel and temperature gauges. The result is that the analog gauges will go dead and your display will have both the temperatures and fuel levels shown in bars.
    The disconnect is just remove the front instrument panel and disconnect the wires to the gauges.
    Quote Originally Posted by jimbombeck View Post
    If you dis-connect it ..... the gauge will become a bar graph shown on the instrument cluster ..... most folks here prefer that ..... Mike
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    If you disconnect both gauges as stated above, you can replace the gauges with two other devices, like a clock and a 12V accessory socket or USB socket.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Sep 2017
    Durham,Maine
    Disconnected mine and got two blanks to go into the holes from BRP, I like the digital gauge better, works for me!
    2012 RTL , Pearl
    Feb 2017
    Disconnected the analogs on both our RTs and replaced them with a voltmeter on the right and a dual USB port on the left. Much nicer and the digital gauges are more accurate as others have said.
    Apr 2020
    Pennsylvania
    so where exactly do the digital gauges show up on the bike?
    Sep 2017
    Durham,Maine
    It will be on both sides of your display screen!! One on one side, one on the other, you'll see!
    2012 RTL , Pearl
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    They show up as vertical bar graphs on the left and right of the digital speedometer. Fuel on the right, temperature on the left.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Jul 2020
    Georgia
    I disconnected both gauges. Both are displayed digitally. However, the temp gauge shows bars. The fuel gauge is not working and the "fuel pump" light is displayed. Any suggestions?
    Sep 2017
    Durham,Maine
    With out being there, you may have a bad sending unit in the tank! Any one else???
    2012 RTL , Pearl
    Quote Originally Posted by lt538 View Post
    That is a new glitch for me. So far, the fix has worked for everyone that has done it. Sounds like "other" problems. Did you try re-booting by using the start-up procedure again? It would be nice if it worked the "second or third" try. Fingers crossed for you.
    Nov 2015
    Chardon, OH
    How much gas is in the tank?
    Doug
    ”Freedom is not a loophole”
    Very Active Member bronzeflex42's Avatar
    Sep 2014
    Sandersville, GA
    This is the main thing i used to hate on my Spyder..
    2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
    Jul 2020
    Georgia
    It has 11miles since I filled up.
    The needle would bounce slightly when I filled up. Then it would bounce more as the miles increased.
    The "gas pump" light is intermittent.
    Jul 2020
    Georgia
    I did restart twice. No change
    Feb 2020
    N. Wilkesboro, NC
    Just out of curiousity (and I'm guessing the answer is "yes"), does this work for all pre-'18 F3s (with the full gauge package). Mr. traveler mentioned 2010 and 2011. I plan on buying a 2018 or newer F3 so it won't matter but would be good info to have if I found a screaming deal on a '16 or '17, I guess.
    Quote Originally Posted by MONK View Post
    My actual knowledge is with the RT 2010 and 2011's. I did the changeover successfully on both. Not needed on my 2014 RT...where the analog gauges are rock solid.
    I am new to the F3 as of December 2019. I am happy with the gauges as they are. Hopefully, an F3 user can give you a better answer to your question.
    Nov 2015
    Chardon, OH
    It is indeed strange. As long as ALL of the wires were disconnected from BOTH of the gauges and you are getting this issue, I suppose if it was me, I would put it back the way it was and see if the gas gauge returned to indicating the correct level when not moving. That would narrow it down to being a sender problem or not. In model year 2012, a new gauge was developed that had some mechanical dampening in the meter movement. You'd still get swings in the gauge during braking and maneuvering, but not as severe as earlier years. After all, the level in the tank is, in fact, sloshing around. There were still complaints about their accuracy at the low end. The gas gauge is not something to stare at anyway. Using the trip odometer, stop about every 120 miles-ish. The Low Fuel light - what you're calling the gas pump light - is independent of the gauge and is usually spot on.
    I recall that you had some other electrical issue with a brake code. What's up with that, although I"m not making any connection between the two as of yet.
    Doug
    Jul 2020
    Georgia
    Tried suggestions, I can ride about 10 miles when it goes into limp home mode and flashes spyder light. Check engine light stays on. Next trip is on a trailer to the dealer.
    Jul 2020
    Georgia
    Quote Originally Posted by Snowbelt Spyder View Post
    .....I recall that you had some other electrical issue with a brake code. What's up with that, although I"m not making any connection between the two as of yet.
    Update on P0504 code. Spyder has been at the dealer since Sept 12. Service Manager called and said "you as re not riding enough, the pistons on the brake calipers are not retracting fully after brake pedal release. Serviced the calipers, pistons and flushed brake fluid. Problem solved.
    Aug 2019
    southwest oHIo
    Sorry, don't know about the F3s, but I can verify that it works on a '17 RT-S.
    Uhhh, this thread has been about a gas gauge issue, not about error codes or brakes.
    Maybe you responded in the wrong thread?
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Dec 2013
    Quote Originally Posted by Steve W. View Post
    But why do you say that Steve?!? It's all there, clear as mud!!
    As for the brake code, see the quote (that now displays properly ) in lt538's post #21 re the brake code...
    You're just not keeping up Steve!!
    Sorry but I hadta....
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Aug 2019
    southwest oHIo
    I can see now where it got derailed.
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
