Results 1 to 11 of 11
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Default New Centramatic wheel balancer & belt tensioner
    I have one Centramatic wheel balancer new never used for rear wheel $50.00 + shipping
    Also a belt tensioner new Fenner Drive T-Max heavy duty for the Spyder $50.00 + shipping
    PM if interested...
    2018 RT Limited "Blondie"
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Can I safely assume the tensioner is for an RT and an easy bolt on product?
    Apr 2018
    It is a bolt on type. Even has the bolt attached to it.
    Apr 2018
    Are you interested? Shipping is $15.45. Let me know.
    Jul 2020
    Florence, sc
    Can you help out with part number to belt tensioner? From quick Google search these look like tensioners for automobiles not Spyder.
    Dec 2013
    Quote Originally Posted by Sammie View Post
    Sammie, if you are looking for or at 'belt tensioners', that's NOT what anyone is using on their Spyders!! The devices used on Spyders might be miss-called 'tensioners', but they are really only 'Vibration Dampeners' intended to reduce or stop the harmonic belt vibration experienced by some Spyders between about 70 & 75 mph - but they DO NOT actually provide much in the way of additional tension to the belt, they only dampen the vibration! On all Spyders, Belt tension & alignment is provided by the adjusters on the ends of the swing arms, and many also minimise the harmonic belt vibration by REDUCING the tension on the belt!
    So if you've used 'tensioner' in your google search, you probably won't get any results that are helpful for your Spyder. But if you go to the Lamonster Garage website via the link up the top right of your screen, and enter 'belt tensioner' or 'Idler Pulley' in the search field, you'll get a result, but you might need to drill down to the 'complete upgrade kit' or something similar to get the whole thing, or you'll just see only the roller that goes on the end. Similarly (altho I haven't checked this one) if you go to the Can-Am website or maybe even www.cheapcycleparts.com & look for parts & accessories/enter your Spyder details & then drill down to the belt etc, you should be able to find a number for the optional belt vibration damper; but if you really want one, why not buy Bigmo's as per this FS: advert??? IIRC it's somewhat cheaper than the a/mkt alternatives & possibly more robust than the OE piece of kit...
    Cheers
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Apr 2018
    This is made by Fenner Drives Part # RT1601-L - It is designed for the Spyder. Still available if interested. I sold the Centramatic.Tension.jpg
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Quote Originally Posted by Bigmo View Post
    PM if interested...
    I would be interested in the wheel balancer if it would work with my 16 RT..!
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Centramatic wheel balancers on the front and rear.
    Rivco dual flag holder
    Tricled mirror turn signal indicators
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lambskin seat cover from Smokey mountain sheepskin.com
    Tricled 360 degree led Headlights
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Spyderpops bumpskid w led light
    Rivco brand footrest
    spydermanexhaust.com exhaust
    had my exhaust installed @ Spyder in the hills.
    Sep 2014
    USA
    Quote Originally Posted by Dmetcalf View Post
    They been sold per post #7
    Apr 2018
    The Centramatic wheel balancer was sold.
    Jun 2017
    Texas
    I contacted Centramatic directly to not only purchase two for the front tires of the Spyder but also get two for the front of my Chevrolet. They’re office is 88 mi. from my place so it would be a nice ride to pick them up and save shipping cost.
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
