Results 1 to 5 of 5
    Jun 2015
    Ritzville, Wa
    Default Headlight Question - are these fogs or what??
    OK, just picked up my 2018 Can Am Spyder RT yesterday and have my first question. Please refer to the picture below.
    In the picture, there are two sets of lights, let's call them the upper and lower. The upper are the headlights. On my handle bars is a toggle switch for the lights. The middle position I believe is for low beam. Toggle up and it turns on the high beams. If you toggle the switch down, the lower lights only remain on as long as you hold the toggle switch. I thought they were the fog lights, but the manual says it's only to flash the high beams. Does that mean the bike does not have fog lights? Is there a way to add them somehow?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Nov 2015
    Chardon, OH
    Look down at the row of switches. Last switch on the right. Page 26.
    Doug
    ”Freedom is not a loophole”
    Note too that the Note, second para in 13), top left of page, says the switch cluster is operational only when the engine is running. The functions the switch cluster activates draw a lot of juice. You have a Limited; it comes with fog lights.
    Jun 2015
    Ritzville, Wa
    Thanks guys, I forgot all about those 2 switches.
    Greg Kamer
    If I'm reading your description correctly, something isn't right. The top position of the toggle is high beam, the middle, as you say, is for low beam, and the bottom is momentary to flash the high beam. That toggle switch has nothing to do with the fog lights. The European version uses the lower lights for low beam and they have no fog light. The lower lights are fog lights and the switch to turn them on and off is part of the dash switch group. If your lights don't conform to this description have the dealer check things out.
