Results 1 to 6 of 6
    Nov 2018
    Tampa, FL
    Default Rear Wheel Removal Help
    Wish I knew how to post a picture.
    Cannot get shock bottom bolt out. Got the nut off and started to back the bolt out, it got at an angle now and I cant move it anywhere.
    2015 ST Limited , Bought the oversize brake pedal and it made the world of a difference. Black
    Nov 2015
    Myerstown, Pennsylvania
    What model? Lifted or on the ground?
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Houston
    You need to remove the weight of the bike off of it. that bolt supports the entire rear of the bike.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2014
    USA
    And did you get the belt off yet?
    Quote Originally Posted by jfl330 View Post
    Some folks here had said " sure it's fine to lift the rear from Under the shock EYE .... I have said NO, not if you want to remove the BOLT .... you need a wood block that is WEDER than the two shock brackets that hold the shock ..... use those as the lift points .... this prevents any pressure of the shock and shock bolt ..... so lower the spyder, get the piece of wood and try again ...... god luck .... Mike
    Aug 2013
    SF Bay Area
    Lift the bike at the rear of the main frame. Then lift the wheel so the shock isn't compressing or expanding and the bolt will slide out. Need to take pressure of the shock.
    2021 F3 Ltd , Magna Red
