Results 1 to 23 of 23
    Nov 2018
    Lisbon, Portugal
    Default Front pads replacement - what tools are needed?
    Going on a trip next week so I might replace the front pads as on one of the sides it should be around 1.5 and 2mm (rear was done recently at the dealer).
    EBC's FA630HH pads are on the way.
    What tools should I need beside the jack?
    2018 F3S , Monolith Black Satin
    Durham,Maine
    For the front you don't need any thing special that you don't have kicking around! Good luck, piece of cake!! Oh, just remembered make sure you put some of that brake paste on the backside of the pads to keep them from squealing! https://www.spyderlovers.com/forums/...4&d=1595901703
    2012 RTL , Pearl
    Nov 2018
    Lisbon, Portugal
    Thanks Mikey.
    From the videos I've seen on youtube:
    I'll need 21mn lug wrench for the wheels and a T30 Torx to remove the locking pin.
    Seems it can be done without removing the calipers so an Allen wrench might not be needed.
    What are the recommended tightening torques for the clip and the lug nuts of the wheels?
    Also would it be OK to lift the the wheel by the lower suspension arm? Instead of lifting the whole front by the frame?
    Can get my hands on that brake paste here (Europe) so I'll have to go without, but I've ordered a good brake cleaner, not sure if it will help though.
    Feb 2012
    Spring City,Utah
    I would think some type of disc brake paste would be available in Portugal. I am sure you have disc brakes there and I am just as sure that they squeal. Check with a brake specialty shop in your area about brake squeal and how they solve it, maybe it is called something else in Portuguese.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    The lug nut torque spec is in your operator's guide. The brake pad pin torque is 46 Nm or 34 lbft. The service manual says to use blue Loctite on the pins.
    Oct 2013
    rome new york
    Quote Originally Posted by MakoShark2 View Post
    Thanks Mikey.
    Yes no need to remove caliber for front brakes
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    You can find the Brake paste on Amazon. I bougth that from spain.
    https://www.amazon.es/Liqui-Moly-307.../dp/B00295ERQ2
    or
    https://www.amazon.es/Liqui-Moly-307...pcontext&psc=1
    2018 F3 Ltd. , Black/Dark
    Nov 2018
    Lisbon, Portugal
    Quote Originally Posted by mcalva View Post
    Yes, LiquiMoly that's the only one I've seen available here, just ordered thanks.
    Nov 2018
    Lisbon, Portugal
    Perfect, thanks.
    Nov 2018
    Lisbon, Portugal
    I lift mine with my Craftsman motorcycle lift and place the jack stands right beneath where there the shock bolts to the lower A-arm. That's the same place where I would place a jack if I was lifting one wheel. I personally would not try to lift the Spyder from beneath the middle of the A-arm without using a well placed piece of 2x6 to spread the load. I just don't know how strong the A-arms are. I may be all wet.
    Feb 2019
    Portland, Oregon
    Lifting by the lower suspension arm is fine. Place a rag in the lift's pad to avoid paint damage. I've done front brake work one side at a time to keep it simple.
    Thanks, Ric.
    Nov 2018
    Lisbon, Portugal
    All the info I need.
    Thank you all!
    Parts should be here by the end of the week, I'll let you know how it went.
    Nov 2018
    Lisbon, Portugal
    So, it's done
    Most of the time was spent figuring how to lift the the front wheels about 2 inches so I coul get the jack under the suspension arm.
    That's because the jack has a pad with about 3 inches of rubber.
    So I had to get creative and I finally managed to place the spyder over a solid wooden door which was enough to then lift the wheels (one at a time) with the jack.
    Everything else came off easily (didn't removed the callipers). Wear was pretty even on the old pads, I had about 1.5mm on the right side and a bit less than 2mm on the left.
    Cleaned the whole thing, rubbed the outter side of the pads with the anti squeal stuff. Pushed the pistons with fingers and placed the new pads.
    Pad pins came off very easily so 46Nm/34lbft seemed way too much for tightening.
    Recommended tightening torque for lug nuts is about 110Nm which seemed right as the wheel material looks kind of soft.
    And I had just finished the second wheel when I saw the little wire pin for the brake pad pin on the floor...
    Thank god I managed to put it back without removing the wheel again.
    Then turned on the Spyder and had a brake failure error message
    Turn it off and on again, and it was gone... I'm assuming this is normal and maybe it must have to do with the ABS sensor reseting itself...
    Anyway I'll check the brake fluid level tomorrow.
    Thanks everyone for helping.
    After you change the pads but BEFORE you turn on the ignition you are supposed to pump the brake pedal several times. If you did not do that, that's why you got the brake failure message.
    Nov 2018
    Lisbon, Portugal
    Oh yes, forgot to mention. I did that to push the pistons back against the pads and the rotors. Pressed the pedal several times until it wasn't soft anymore.
    Since the code did not come back the second time you turned on the ignition switch it is not active. If you get dealer service for anything have them check for and clear any inactive codes.
    Nov 2018
    Lisbon, Portugal
    All good.
    Just got home from a 1500 miles trip with no issues.
    Real good brake power and no "squealing" anymore.
    I do noticed a "swwwishhhhh" sound when braking which I'm not sure I had with the stock pads.
    Thank's to all.
    Now thinking on doing the annual maintenance myself. Got to check if it's just replacing oil and filters and what I'll need.
    Jan 2021
    Clemmons North Carolina
    I have a question and I may be asking a dumb one...but I see a lot of what is the torque specs but my question is when your tightening a bold how do you know you have tightened it down to the specs in the book? is there a tool for that...I usually just tighten things down hand tight or until i cant tighten anymore...am i looking at it wrong?
    Feb 2019
    Portland, Oregon
    Google bolt torque guide or something similar and you'll get charts like this one.....
    https://www.fastenal.com/content/mer...ce%20Guide.pdf
    Feb 2012
    Spring City,Utah
    Kennygee what you are looking for is called a torque wrench. It has a dial, indicator pointer or release point that tells you when you have a hit the correct torque. Snap on MAC, Harbour freight, Amazon, all have them at various prices. I have an old 3/8 drive Snap on Clicker (release type) that I use. I have had it since 1972.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Jan 2021
    Smile Tools..
    Thank you for the fast reply...I was watching a YouTube video of a guy that says a quote and I think its his you tube name....IT'S YOURS, OWN IT...so it is awesome having this family of spyder riders to learn from...
