Results 1 to 24 of 24
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Default Another 2020 RT issue solved!
    A major issue I've had with my new 2020 RTL has been that the "glove box" that is intended for you to put your phone in while using BRP Connect, gets extremely hot. This console is directly above the engine and gets a tremendous amount of radiant heat, both while riding, and when parked. My phone has even given me a warning that due to overheating, it was closing some apps. I covered this box with a heat shield product that is able to withstand 400° direct heat, and 2000° radiant heat. It's self adhesive and the only draw back is that I can no longer read the warning label that tells me how to start the bike After a 20 mile ride at 90°F, the inside of the plastic box was actually cool to the touch!! It's not cheap; it was about $23, but it is saving a very expensive cell phone from overheating.
    2020 RT Limited , Marsala Red
    Feb 2016
    Our site sponsors should glom onto this as a new product offering!!!!
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    A fix for a Spyder issue that cost $23!? Sounds like a cheap fix to me.
    Jul 2020
    SE Pa
    Jetfixer would you share the name of the insulation wrap you used? TIA!
    Feb 2016
    Where did you purchase this?
    Sep 2017
    Durham,Maine
    https://www.carparts.com/jc_whitney
    They have all of that sort of stuff!
    2012 RTL , Pearl
    Mar 2013
    I did not find it there, but did find this-
    https://www.jegs.com/i/Thermo+Tec/89...r%20Categories
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Feb 2016
    Quote Originally Posted by Challenger View Post
    I used DEI Performance Products Reflect A-Cool. It's stocked at most major auto parts stores.
    Mar 2013
    Maumelle, AR
    Ebay has it for $14.30 plus tax w/ free shipping. I just ordered mine. Thanks Bret.
    https://www.ebay.com/itm/163908618610
    2020 RT Limited , Chalk
    Active Member JimFoy's Avatar
    Aug 2012
    Farmersville TX
    I ordered a sheet off Amazon and installed it on the outside of my glove box. It made a world of difference.
    Jan 2020
    New York
    Quote Originally Posted by JimFoy View Post
    Same for me. Night and day difference!
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    The RT models which retail for almost $29K have been around for over a decade and the heated glove box issue has been carried over and over after several improvements and redesigns of the Spyder. Sometime I just wonder what those engineers and managers at BRP are thinking, or not thinking. I am amazed that we are so proud of ourselves fixing the problems that should not exist in a vehicle costs that much.
    Cheers.
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
    Jun 2020
    Southern California
    Did it affect the phone signal? Or range?
    Jan 2020
    New York
    Quote Originally Posted by Papaloco View Post
    I have not seen any noticeable difference in signal reception. Although I did leave a piece of the top of the glovebox uncovered for heat to exit.
    Feb 2016
    None that I can tell either.
    May 2020
    E. Central Illinois
    Quote Originally Posted by Jetfixer View Post
    This stuff works!!! Went for a ryde yesterday, temp in the mid 80s, after about an hour, I checked the glovebox and it was cool inside. Might trust putting my phone in there now.
    Jul 2018
    Northern New York
    I have a 2021 RT Limited and i get Zero heat in the glove box.Dosent even get warm. I keep my back up pistol in there.Fits perfect. I checked it today after a 60 mile ride and not even warm. Perhaps This is one of the few differences between the 2020 and 2021...anyone else with a 2021 notice no heat?
    Jun 2010
    Maryville, TN
    Same here, just picked up my 2021 RT Limited and the glove box is staying cool. I rode about 100 miles and my phone stayed cool. They must have made a change between 20 and 21,
    Jul 2018
    Northern New York
    Quote Originally Posted by Jimmur View Post
    I went 128 miles yesterday and checked it again for heat...not even warm!Your right they must of made a change between 20 and 21..Curious what other changes they made.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by trong View Post
    Cheers.
    People think that engineers run these companies. This is why I always chuckle at those who respond to a modification by saying 'If the engineers thought this was a good idea, they would have included it in the design'. Or, 'I'm not switching because the engineers know what is best'. And I agree. The engineers probably do know whats best. But it's the pencil pushers and bean counters who run the company. It always comes down to the bottom line. And you have to know that, many times, the engineers walk away shaking their heads.
    This is what keeps aftermarket people in business. We do what the engineers wish they could.
    Jul 2015
    Dorr, michigan
    so very true. It all comes down to added cost, not just the cost of the material, but the labor to install it also.
    2020 RT Limited , Petrol Blue
    Jul 2015
    Dorr, michigan
    Mine stays cool while I ride (2020) but when I stop for a break the heat goes up and into the box, warm enough to cause my phone to close apps. NEVER happens if it is moving down the road.
    Aug 2020
    Shenandoah Valley
    Default Cool n' not
    Quote Originally Posted by Fatcycledaddy View Post
    I Second.
    I've kept an eye on the issue since reading this thread. I found the same results as you Fatcycledaddy. The glove box does get stinkin' hot when I park for a few, but remains cool when moving.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Just got back from the Red Rock Rally and found that when crossing the desert in 100* plus the iPhone shut down while in the glove box due to the heat. Opening the glove box and allowing the air to circulate solved the problem while traveling, but for the longer term I'll be grabbing some of the thermal barrier. Thanks for the ideas.
    2020 RTL SE6
