Results 1 to 14 of 14
    Sep 2020
    OH
    Default 2014 RSS SE5 won't start
    Hey guys I bought. 2014 spyder RSS SE5 a month ago, has 7700 miles took it to work last Monday and it stalled out at three red lights and then wouldn't restart. Put the tender on it overnight, started then stalled. Now won't start at all. Replaced relay, added fuel injector cleaner and dry gas, still nothing. Help please I know nothing about mechanics and am lost.
    Active Member CarolinaSpyderRyder's Avatar
    Jul 2015
    North Carolina
    Is the battery new? I would start there.
    2014 RSS , Sunburst Yellow and Steel Black Metallic
    Sep 2020
    OH
    It is not new. Lights and everything work, would that matter?
    Durham,Maine
    Take the battery and have it LOAD TESTED!!! Start there, then all connections clean and tight, then tell us how things work!! Good luck
    2012 RTL , Pearl
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    When you say "it won't start". Do you mean it won't turn over or it turns over , but won't run?
    Bob S
    Sep 2020
    OH
    Won't turn over
    Durham,Maine
    Check your kill switch!
    2012 RTL , Pearl
    Aug 2008
    Maryland
    Yep been there done that
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Sep 2020
    OH
    Actually a friend of mine had the same problem (kill switch) we played around with it and it didn't seem to matter. I'll try taking it apart when I get home
    Sep 2020
    Platte City, MO
    How many volts does your battery show? What does the voltage drop to when you try to start the Spyder? These are the things to find out
    before you try anything else. Lights, horn, radio can all work, but the voltage can be too low to start it. Get out the ol' VOM and check it out.
    Sep 2020
    OH
    Battery is fine, took and had checked
    Sep 2020
    Platte City, MO
    If you know the battery voltage is good, and your alternator is doing its job producing enough voltage to keep the battery charged, and the bike
    won't turn over, then it's time to start looking at stop switches, like the Kill switch, or any other switch that will keep the starter from engaging
    when the button is pushed.
    When it "stalled" at the light, did it just die while idling, or when you attempted to start moving again, or perhaps when you put it in gear.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Sep 2020
    OH
    First time idling at light, restarted and then stalled when I put it in gear, last time idling at another light
    Bossier LoUiSiAna
    Mine had similar stalls thanks to bad purge valve most aggravating & almost random, would not be every stop sometimes just <5 ~10mph parking lot speeds more often on off ramps as SE got to second or first gear just yielding & would stall apparently over filled the tank & between sloshing & or not so steep parking garage uphill downhill was enough. Usually would crank right back up though sometimes the push mode screen would show up while at speed
    https://www.spyderlovers.com/forums/...4-Picture-game
