Results 1 to 8 of 8
    Feb 2020
    Sheridan, Wyoming USA
    Default Just how bad can tires be?
    So I thought my wife's '11 RT had eaten the inside edge of the right front Kenda a bunch in just the last few short trips she's taken, and I am planning on trailering the bike to a laser alignment place in Spearfish, South Dakota as soon as the 15 inch wheels and Vredesteins I ordered get here. Well, we went and gassed up an hour ago, and I looked at the tire and thought, "Wait a minute...there's more tread than I remember!" Yeah. The tire has not only worn on the inside, it has worn DRASTICALLY unevenly around the circumference, so depending on where the tire is in its rotation, it looks either bald as a cue ball or just to the wear bars. So while it still may have an alignment issue (and definitely need new shoes!), the bizarre wear on the right combined with even wear on the left tire, centered handlebars, lack of wander, and equal left-to-right steering effort is leading me to wonder if the problem is actually a defective tire. I still intend to get it aligned, but I am gonna be hella mad if it turns out it was just the rubber and I spend a hundred bucks on gas and meals, waste a full day going to another state, and possibly spend another 120 to be told there's nothing wrong with the alignment.
    May 2017
    Mesa, Arid-Zone-A
    You're not wasting your money...... Jim
    Semper Fi
    If it's an OE spec Kenda, they can be 'out of round'; have bulges in them; have tread that separates; have tread &/or tread plies that were run off the tread face & blended inches over into what should be the sidewall during construction; have dirty great overlaps &/or gaps in the various construction layers; and more!! So if you get away with it JUST being a defective tire that caused that sort of irregular wear, maybe you should consider yourself lucky that it's lasted as long as it has with little calamitous impact on your/your wife's ryding! . Others have had far worse!
    However, in all fairness, I hafta add that the tire wear you've shown us/mentioned COULD be due to a bunch of other things too, not all of which relate specifically to 'poor quality tires' - things like an 'un-balanced' tire or heavy braking causing flat spots; defective/failed suspension components; worn ball joints, shock absorbers, 'A' arm bushes; or even collapsing springs/incorrect spring pre-load. All of those can create dodgy/odd wear patterns.... altho they generally tend to be wear patches concentricly spaced & of equal depth around the circumference of the tire, even if not always!
    But canamjhb is right, you really won't be 'wasting your money' by getting a competent tech to look at it and to do a wheel alignment before replacing those tires!
    I concur with Peter ( as usual, not because He's a friend, it's because He speaks the truth ). From info provided by many, many members here about their Kenda's, I have concluded they have the Worst " defective tire ratio " of any tire I have ever heard of - Period ....... To be 100 % honest, as long as your Kenda isn't a " defective " one, it can provide decent FRONT tire mileage - if you have proper alignment.... However for the rear it's really hopeless ... 12,000 mi. avg. max miles..... jmho .... Mike
    Jun 2017
    Rapid City, SD
    Going to Outdoor Motorsport for the alignment? I might have to keep that in mind in the future.
    Deadwood and Hill City are already having bike parking on Main Street. The Rally’s come early this year.
    HE>I
    2017 RT , Asphalt Grey
    Sep 2019
    Canton NC
    Quote Originally Posted by RapidSpyder View Post
    Going to Outdoor Motorsport for the alignment? Might have to keep that in mine in the future.
    I agree with Peter also, if for no other reason than to read another 4000 word dissertation from him on all things Spyder!
    Aug 2019
    southwest oHIo
    Quote Originally Posted by NoahMercy View Post
    ... is leading me to wonder if the problem is actually a defective tire.
    Does it say "Kenda" on the sidewall?
    I agree it won't be a "waste", but get the alignment AFTER you get the new rubber.
    Even if the alignment is perfect, you will KNOW that it's perfect.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    Y0ep. Sturgis is super busy already too. Constant bike noise from the interstate at our place. I think thier estimate of 250k might be low this year... but since noone can.go anywhere else and likely have built up PTO... guessing lots will come and stay longer than usual.
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
