Results 1 to 12 of 12
    Jun 2020
    Maryland
    Default 2019 f3 limited - how wide at the front?
    Physical dimensions, width of the front.
    Trying to see if it fit in my 6x12 the rear opening is 61"
    And according to what I find online the width is 58.9 in wide
    Just wanted to see before I empty the trailer
    Thanks for the help
    Sep 2017
    Durham,Maine
    Stretch your tape and measure the trailer, then walk over to the bike and check that!!!
    2012 RTL , Pearl
    Jul 2020
    Rock Falls,Illinois
    Quote Originally Posted by Mcolabella View Post
    Thanks for the help
    Just measured mine and it looks like it's 60" gonna be a tight fit !!
    Jun 2020
    Maryland
    Quote Originally Posted by RonandChris View Post
    Thats what thought, where did you measure on the front,
    I assume the outside of the fenders
    I had the same issue ... very, very little clearance ... I solved it by screwing down wooden RAILS ( like what they have at any automated car wash )
    .... this will keep the tires inside the opening .... I have some pics in an Album ..... Mike
    Active Member rmag's Avatar
    Jun 2015
    miamisburg, ohio
    Automated cat wash because they really don't like to be hand washed... I'm as bad as the next as far as typos. But sometimes they're just to funny!
    2014 RT Limted, platinum, with matching 622 trailer.
    Ultimate tall boy seat w/adjustable back rest, Corbin armrests, Spyderpops bumpskid & missing belt guard, BRP side air vents, Lamonster lidlox, cargo nets, Stebel air horn, Wrap my spyder accents......and more
    Jun 2020
    Maryland
    Can you post photos
    Mar 2017
    Similar to rails. Opening is 63 inches.
    Jun 2020
    Maryland
    Quote Originally Posted by Rattlebars View Post
    You cut the sealing flange, I was just thinking about doing the samething.
    Oct 2019
    indiana
    Get a framing square and find the widest point on each side with chalk on the ground. then just measure the distance between the chalk marks
    Jul 2011
    Mitchell, Ontario, Canada
    From page 181 of your owners manual.
    2018 F3 LIMITED
    Mar 2017
    I cut it with an angle grinder using a cut off wheel. Easy. I put some door edge guard on the edge to prevent scratches in case I've had a few before loading! I thot about sealing it up with a magnetic strip but found that it doesn't need sealed.
