Results 1 to 25 of 27
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default I get a strange vibration at higher speeds...
    ... that feels like running over the rumble cuts on the side of the highway. I’m running at 75 on the interstate and if I accelerate when the byke gets to 77 I feel the vibration. I don’t feel anything in the steering so I wonder if it’s engine? Odd vibration. Stops when I back off the throttle. What might this be?
    2019 Spyder RTL. All stock.
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    I have a new 19 RTL but I haven’t felt the vibration you describe in it. It’s still on break-in miles though.
    My 14 ST had a similar vibration to yours at freeway speeds. I paid very close attention to the source and found the origin was the exhaust system, not tires or drive belt. The fact that it goes away when you back off the throttle would tend to support it being exhaust-related I’d think.
    Good luck!
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Aug 2018
    Chicago
    Its the belt. you need belt tensioner.
    Florida Swamp
    A 2019 should have a factory belt tensioner. My 2019 F3-S had one stock.
    2019 F3-S , Black & Silver
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    Our 2018 RTL does the same thing at about the same MPH. The trikes we ride have a very long belt, and at certain RPM's a vibration is set up that can be felt through the bars and seat. I can make it stop by backing off or adding to the throttle, but when it returns to a steady speed and to that certain RPM the vibration returns. A tensioner dampens the movement on the belt as the trike is ridden so it is not felt or felt very slightly. Vibration can also be caused by a damaged tire or wheel, bad balance, something in the suspension or any cause mentioned in previous (or future) posts.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by Gwolf View Post
    That's unlikely. My '18 RTL didn't have one and the '20s don't, either.
    Clinton, MS
    Nope, not on the 2019 RTL
    Florida Swamp
    It must be only on the F3-S.............
    No clue why Can Am would only fix the vibration on one model.
    Durham,Maine
    Have you check the tension of your belt lately, maybe it time?
    2012 RTL , Pearl
    Jan 2015
    southern WI
    Most likely the drive belt. Very few people get one that doesn't have some amount of vibration around 73mph.
    2016 RTS , Pearl White
    Aug 2016
    I will get the belt tensioner for my 2019 RTL. I am moderately skilled at some mechanical projects. Can I install the belt tensioner myself? Where can I purchase one? Thanks for the help on this.
    Clinton, MS
    Try this. http://www.lamonstergarage.com/can-a...ley-lamonster/
    You want the RT Belt Tensioner With Upgrade Roller
    Durham,Maine
    Check your belt before you go for the tensioner, try to see if you can live with out it, it will be just another thing to watch and maintain if you put one on! Good Luck, ride more worry less!!!!
    2012 RTL , Pearl
    .... also consider this - is the vibration so annoying that you are willing to possibly having to re-place your drive belt ( @ $350.00 ) if the roller on the tensioner fails and ruins that belt ( this has occurred to people on this Forum ) ...... good luck ..... Mike
    Nov 2017
    San Francisco Bay area
    FWIW My 2015 RTL that I bought used also had this problem at 73 mph without fail. I thought it was the belt as well given everyone's experience. When I changed from the stock Kendas on the from the vibration went away.
    So in my case, it had something to do with the tires, I'm not sure what I only know I don't have the problem anymore.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Aug 2016
    I'm curious about what the damge will be to the belt becasue of the vibration. Won't the vibration cause misalignment, skipping teeth, or something like that? I'm not a mechanic and cetaily not an engineer.
    Jim
    Aug 2016
    Quote Originally Posted by LeftCoast View Post
    (snip) When I changed from the stock Kendas on the from the vibration went away. So in my case, it had something to do with the tires, I'm not sure what I only know I don't have the problem anymore.
    The tires were brand new with only 300 miles (now at 640) at the time of the vibration showing up about 76-77 mph. How did you know to check and replace the tires?
    Jim
    Active Member sandylolee's Avatar
    Oct 2019
    NC
    I have a 2019 Rtl had the same problem. I purchased one of Lamonster’s vibration dampeners now no more vibration. Just remember it’s one more thing to keep a check on for regular maintenance.
    2019 Rt limited chrome , Phoenix orange
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    The vibration is an option for former Harley-Davidson owners only.
    Cheers.
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
    Florida Swamp
    Quote Originally Posted by trong View Post
    Cheers.
    Not even close........ the front tire of my old hard mount Sportster would jump off the road sitting at a red light idling.
    Faribault, MN
    Quote Originally Posted by BigGuy66 View Post
    Jim
    Jim, many Kenda tires just had balance anomalies, some don't at all. But I'd follow the check your bikes belt tension first, then consider the Belt tensioner (less expensive than a front tire swap), it's easy to install and remove if it doesn't fix the issue, then replace tires if the tensioner didn't fix it.
    My '13 RTL has both the belt tensioner (one more maintenance check you gotta do if you add one) AND non-kenda front tires. It's pretty smooth through my whole speed comfort zone.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2015
    forrest above Reno, Nv
    MY came with such bad tires that they couldn't be balanced. Dealer switched out tires and rims. Took them off a floor model RTS. Feel sorry for the person who bought that bike.
    Lew L
    2014 RTS , Circuit Yellow
    Quote Originally Posted by Lew L View Post
    Lew L
    Yea, however the dealer may have gotten BRP to re-place the Bad ones ????? .......... Mike
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Jim
    Just had my belt tension set by dealer during first service. Vibration gone. I’ll likely request tension check for all future service visits
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Jul 2016
    South Carolina
    I have to agree, its the tires. I would get a vibration at 76 mph and it would go away at 80. It would come back in the 90s and went away. I couldnt find anyone who could fix them. BRP is aware of this. Either live with it untle the tires wear at which time your vibration will go away. Or simply change out the tires to non OEM tires. I would say the easiest thing to do is to change out the tires. BTW, it has to do with the tread pattern. Thats why on the 2020 the tread pattern is different and this problem no longer exists.
    2016 RTS , GPS, entertainment cable. Outlets in trunk and trunk. White
