Results 1 to 4 of 4
Hybrid View
    Osoyoos, BC
    Default What's happening with all these error codes?
    Just got my 2016 Spyder RT back from repair shop (about 75 miles away), after having an accident ("nuther story), been riding for about 2 weeks, yesterday I went to start it, message came on "Limp Home Mode", and the "check engine light" came on. Poked around for a while, found I couldn't even shift.
    Did a check on "error codes, it showed up a whole lot of them, as follows:
    U0100, U0259, C0063, C0061, U1160, U0128, U0073, U0155, U0122, COO6C, P0000.
    Could anyone suggest what might be happening. Could these still be left from my accident. Actually I ran into a rock on the highway, about 8" x 16" x 6" high, did a lot of damage, including bending the frame, breaking a lot of the plastic, and punching out the radiator. It took about 2 1/2 months to get it repaired and back on the road.
    Last edited by Peter Aawen; 07-31-2020 at 10:25 PM. Reason: Not a 'How To:' DIY thread, but a 'How do I?' question
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    First, this link lists codes
    https://drive.google.com/file/d/0B-N...J5YXRnY1k/view
    Unfortunately, it is not a searchable PDF.
    Judging from the first couple I found, you may have wiring damage and/or poor connections.
    Some may only be a fuse.
    U codes start on page 29.
    Quote Originally Posted by Korthner View Post
    If this was how it was returned to you " allegedly " repaired .... I think the dealer you took it too needs to answer some questions .... jmho .... good luck .... Mike
    Osoyoos, BC
    Default error codes
    Could anyone suggest what might be happening. Could these still be left from my accident. Actually I ran into a rock on the highway, about 8" x 16" x 6" high, did a lot of damage, including bending the frame, breaking a lot of the plastic, and punching out the radiator. It took about 2 1/2 months to get it repaired and back on the road,
