Results 1 to 16 of 16
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default I'm confused about the air bag on the 2019 RT
    The operator's guide describes two different methods for the air bag. The guide describes a "manual adjustment" and an "automatic adjustment." My new 2019 RT Limited has a Schrader valve under the seat just like my old 2010 SM5. I assume that I DO NOT have automatic adjustment and I am back to filling the air bag every time I ride with my wife on the back. Is this true? If it isn't automatic, why isn't that a feature of the Limited?
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Jan 2019
    North Carolina
    My understanding is that RTL's have the automatic airbag. My 2013 also has a soft to hard adjustment toggle under the dash.
    Clinton, MS
    Quote Originally Posted by BigGuy66 View Post
    Jim
    The Limited version of the 2019 RT is automatic. While there is a schrader valve under the seat, if you add or let out pressure it will just self adjust back to where it wants to on your next ride.
    Jul 2020
    home
    Is there an easy method to deactivate or override (temporarily) the automatic function to change the air pressure and not have it self-adjust back to what it wants?
    Aug 2019
    southwest oHIo
    This might be a good time to point out how the "automatic" part works.
    The ride height selector is one of the switches below the handlbar, and is curiously labeled "SOFT ... HARD". It should actually be labeled "LOWER ... HIGHER".
    Anyway, pressing either side of the switch should wake up the display on the dash to show what position the setting is in. A second press will either raise or lower the ride height. HOWEVER, for it to change, the engine has to be running, the transmission has to be in gear (not Neutral) and the parking brake must be OFF. When those conditions are met, the system will add or subtract air to meet the desired height.
    I have proven this with my wife's '17 RT-S, which also has auto ride height. With the wheels chocked, brake off and the trans in first gear, I selected the middle height position. We were doing this at night, so we could see the headlight aim change across the yard as the bike level changed. Once the height stabilized, my son stood on one rear floorboard, I stood on the other (combined weight is about 35 stone). It took several cycles and maybe close to a full minute, but enough air was added to bring the headlights down to where they were when we started. When we got off, you could hear the valve hissing as it released air, but the headlight aim soon returned to normal.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Durham,Maine
    Quote Originally Posted by Gray01 View Post
    What are you trying to do, why do you want to temporarily over ride it?
    2012 RTL , Pearl
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    If I recall, the 18- on up RTLs don't have the adjustment switch anymore. It's all automatic.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Clinton, MS
    Quote Originally Posted by Wahrsuul View Post
    You are correct.
    Feb 2020
    N. Wilkesboro, NC
    I asked this same question a while back. Apparently, the Schrader valve under the seat is to dump the air to aim your headlights.
    Oct 2014
    Fort Mill, SC
    There is a Schrader valve on all airbag systems, regardless of being manual or automatic.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Grandpot View Post
    My 2018 F3L does not have one.
    Oct 2014
    Fort Mill, SC
    I stand corrected. I wonder why not? It will come in handy if the compressor fails.
    1998 Honda Valkyrie
    US Navy Veteran
    Aug 2016
    I knew that I could count on you all to give me the informtaion I needed. Thanks - I'm glad I don't have to add air every time my sweetie wants to ride.
    Jim
    Jul 2020
    home
    To adjust it to where the operator wants it (rather than where the device wants it) on command.
    Jul 2011
    I was sort of surprised myself. But if there's a leak. The reason the compressor fails generally. Then the Schrader valve does no good until the leak is found and fixed.
    Aug 2019
    southwest oHIo
    Jim
    When you have a few minutes to spare, follow what I did in post #5 to verify that your system does, indeed, auto-level itself.
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
