Results 1 to 9 of 9
    May 2020
    Virginia
    Default Passenger phone holder and charging
    First time poster, I have searched the forms but I can't find where anyone has installed a charging port and phone mount for the passenger. (I have a 2020 RT (not Limited). I don't have the top case. Need some suggestions on how to go about doing this.
    Thanks,
    Rob
    Northern Kalifornia
    Motorcycle Dave has a good holder for a passenger's phone. Get a long battery tender lead and run it up under the seat for a passenger phone charging option. Store it under the seat when not being used.
    Jul 2018
    Nw wi
    How about just put it in your pocket.
    May 2020
    Virginia
    Can't charge in a pocket
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by Rob4570 View Post
    Sure you can, just put a portable charger in with the phone. On our 2015 RT-S there is a hole plug to the rear of the handle. I removed the plug and reamed out the hole and ran a wire from the trunk lighter socket to the new hole and installed a usb port in there and in the trunk, and put a phone holder on armrest. Use a retractable usb cord for "Managements" phone.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Sep 2017
    Durham,Maine
    I say unless the passenger is giving directions or has to change the music on the Bluetooth, put it in the back where she can charge it and sit back and smell the roses and be unconnected!! I can just see a very expensive phone going down the road without it's owner!! just saying!!
    2012 RTL , Pearl
    May 2020
    Virginia
    2020 RT does not have a rear compartment.
    Dec 2013
    I can see that you've said your 2020 RT doesn't have a trunk/top case, but what about under the cover where the trunk would go on the Limited versions? Or in the panniers?? You've still got those, don't you??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    May 2020
    Virginia
    I can't find a customer assy circuit to connect to. there is the large plug receptacle that would be used if I had a top case, but don't have a way to connect. I do have two blanks that would be used for the heated passenger seats. I was just trying to find out if anyone had installed one on a 2020 RT so I could pic their brain.
