Results 1 to 13 of 13
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default Is there a "not less than" for RPMs on the SE6?
    I am new to the SE6, coming from a 2010 SM5. With the 998 there was caution not to 'lug' the engine with RPMs too low. On my new 2019 RT I shifted the SE6 about 3500 during this break-in period. Is it possible to have the RPMs too low for any of the gears? Trying to understand how this SE6 works.
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Quote Originally Posted by BigGuy66 View Post
    Jim
    Well the SE trans can't stall because of low RPM's ..... it will just downshift .... and the SE won't let you up-shift unless the engine has reached the level of rpm's that allow it it to do so safely ...... the 1330 engine was designed with low rpm's / high torque as it's power production ..... Mike
    Aug 2019
    southwest oHIo
    I am also rather new to the SE6, but it's the only Spyder we have had, so have no comparison.
    Based on engine sound, it doesn't like to be under 2k. Just riding through town, staying with or slightly ahead of traffic, shifting at 3.5k seems to work. Overall, we tend to keep it over 3k, there's no need to keep it wound up like the V-twins.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Dec 2013
    The clutch on the SE6's works on oil pressure, unlike the SE5's where the centrifugal clutch works on revs; so as long as your SE6's engine is running & you've actually got a gear selected, the clutch will be happily doing its thing!
    That said, the gearbox itself is still a manual gearbox, just with a snazzy clutch and super-fast electronically controlled gear changes, so you aren't really being all that kind to the engine/drive-line by letting it do all the down-shifting - that 'automated down-shift' is simply the other side of the computer not letting you up-shift too early - it's a 'fail-safe' to stop things being damaged by 'poor driving practices', like forgetting to change down when you really should &/or trying to change up too early... either can result in putting too much torque thru the higher gears, and that might just cause some fairly expensive damage!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jul 2014
    Mint Hill, NC
    The SE6 transmission automatically downshifts if the engine drops to 1,900 RPM or thereabouts. Take the Spyder out and run it up to 6th gear and let go of the throttle and watch it automatically downshift all the way down to first.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2016
    (snip) the gearbox itself is still a manual gearbox, just with a snazzy clutch and super-fast electronically controlled gear changes, so you aren't really being all that kind to the engine/drive-line by letting it do all the down-shifting (snip)
    So - I should do the downshifting and not let the byke automatically downshift? I think that's what you are saying... I don't want to grind up any gears!!
    Jim
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Mine seems comfortable shifting up 3500-4000.
    If I want engine braking to help more on a downslope I’ll downshift about 2500-2800.
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Jim
    I let my machine downshift by itself 98% of the time. The only time I manually shift down is when I want extra power to pass etc.
    Jul 2014
    Mint Hill, NC
    The Spyder isn't going to care whether you shift or it shifts. I have not heard of a single case hereon where an SE6 transmission has crapped out because the rider did all the downshifting.
    Cognac 2014 RT-S
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    I usually downshift myself down to 2nd gear and let it go into 1st when it wants to. Letting it downshift itself seems to have a rougher feel to it. Besides, I guess I am a control freak. I want the gear when I want the gear. (driving sports cars too long)
    Nov 2012
    Pueblo Colorado
    Default Downshift if you want to turn and burn - Torque bump abive 4500 RPM
    Most of the time I cruise and shift with the RPMs above 3000, but when you pull out to pass a semi at 60-65 its nice to drop a gear and get the extra 10 to 15 percent torque peak.
    But its worth noting you still have 80 lb feet of torque at 2000 RPM for cruising; when slowing down the autoshift is around 1700 RPM except to first at 1400 RPM.
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    If you want to see the design philosophy, simply engage ECO mode and you'll see where the shifting is supposed to occur for maximum fuel economy. For normal driving, around 3000 seems to be a happy middle point. For fun, there's a reason you can hold each gear up to redline!!!!
    2020 RT Limited , Marsala Red
    Apr 2019
    Florida Swamp
    You can't lug the engine on the SE6. If you get below about 2,000 RPMs the clutch disengages after it has shifted back down to first. Without bringing the RPMs up, you have no power to the drive wheel.
    2019 F3-S , Black & Silver
