Results 1 to 7 of 7
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default How can I upload a signature image?
    I want to change my signature picture to my new Spyder. I did a search and didnt find an answer... When I try to "insert image" it will only let me use the URL upload, not the "from computer" option. I don't know how to use a URL... I changed my avatar using the "from computer" option. What do I need to do?
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Dec 2013
    Hi Big, as you might notice, I've moved your thread to the 'Forum Support & Testing area - a better place than General Spyder Discussion for this sorta stuff.
    Hopefully you can follow all this, but I can assure you that it's a whole lot easier to actually DO than it is for me to type it out!
    First up, click on 'Notifications' & then 'Inbox', up in the top right of screen. Once that page paints up, look down the left hand column for 'edit signature' and click on that. That'll open up the (funnily enough ) 'Edit Signature' page and if you scroll down past text field, you should find a block that says 'Signature Picture', and Option 2 in that block should be labelled 'Upload image from your computer' - that's where you need to click on 'Choose File' and follow the selection process.
    Help any? Just yell if you still need a hand!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    It works. Thanks Peter.
    Aug 2016
    Pembroke, Massachusetts
    Hope it works
    Nope!
    Aug 2016
    Try again
    Nope
    Dec 2013
    Hi RNBob, did you 'Choose File'; select where from, ie your camera or files etc; select the file & 'done' to return to the 'Choose file' field, where your selected file name/addr shows alongside the 'Choose file' button; then hit the 'Upload' button just below & to the right of that block??
    Not saying this is necessarily what's happened to you/your pic, but it does seem that some will choose their file OK but then forget to Upload it..... and that just won't work!! Do I really need to tell you how I know this occurs.... more than once, too!! At times, it's not that my 'memory' doesn't work quite so well anymore; it's more that my 'forgetory' seems to kick into high gear more often!!
    Aug 2016
    ...and you need to Save Signature above the picture section... at least I did.
