Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 84
  1. #51
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Yes 9300 mile interval Amsoil 20/50 1330 cc 53000 miles
  2. #52
    Active Member Papa103's Avatar
    Aug 2019
    Maine
    Here is my first oil analysis ever. After discovering BRP doesn't offer full synthetic and recommends regular oil (semi synthetic) and they say to go 9300 miles, I decided to send the oil out to get analyzed. I did the first oil change at 2000 miles. The second one at 8000 miles. I ran the second oil change 6000 miles. The only part of this analysis I really understand is the note they wrote back to me. If any one can explain the rest that would be greatly appreciated. End result BRP XPS oil seams to stand up well except viscosity. That didn't seam to bother the analyist. I am going to stay with XPS, but my oil change intervals will be at 5000 miles.
    2021 RTL Chrome Deep Marsala
    HELI Bars
    Garmin Zumo XT
    USB power port
    Front fender lights & Sequential turn signals
    Front LED Auxiliary light
    Flashing brake module TricLED
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    2021 RT Limited , Marsala Red
  3. #53
    Durham,Maine
    Stop over thinking this subject, use what ever meets or exceeds the manufactures spec, and what ever you can afford people!! Stop worrying that your doing some thing wrong, when was the last time YOU blew a motor up! TIRES AND OIL what a waste of time!! But why do people go to the race track??? Because they love watching a good crash!!!
    2012 RTL , Pearl
  4. #54
    Jul 2011
    Mitchell, Ontario, Canada
    It's on a roll. You can't stop it now.
  5. #55
    Sebring, FL
    I like a good oil thread, maybe it's a waste of time, but that's OK.
  6. #56
    Quote Originally Posted by Papa103 View Post
    ...End result BRP XPS oil seams to stand up well except viscosity. That didn't seam to bother the analyist...
    The analyst was not concerned about the viscosity shearing down because in motorcycle engine & transmissions systems that share the same oil, as does the 1330 engine and SE6 transmission, the transmission gears beat the viscosity down fairly quickly, some oils in a little as 2K miles, but the viscosity level then remains pretty stable. A BRP Care guy named Steve explained that to us in early 2015 or so.
  7. #57
    I'd really like to see an oil analysis of Amsoil/M1 10w40 or Castrol 10w50 after a BRP stated 9000 mile run time. Has anybody ran their oil for 9k miles?
    This what you want?
    https://www.spyderlovers.com/forums/...t=oil+analysis
  8. #58
    Nov 2012
    North Las Vegas, NV
    [QUOTE=troop;1531882]I'd really like to see an oil analysis of Amsoil/M1 10w40 or Castrol 10w50 after a BRP stated 9000 mile run time. Has anybody ran their oil I ran the Amsoil for 9,666 miles and Blackstone Labs said I could try running it to 12,000 miles. Holds up excellent in the 1330.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  9. #59
    Nov 2012
    North Las Vegas, NV
    I ran Mobil 1 4T for 8,600 miles and it was okay but the viscosity was a little lower.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
  10. #60
    Mar 2015
    forrest above Reno, Nv
    Question Help
    Help
    Did I buy the wrong oil ??
    Got a good deal on Amsoil 10w-40 XL motor oil. Not JASO rated. I'm sure I could use up this stuff in my car but will it cause clutch slippage???
    Does not say energy conserving.
    Thanks in advance for your advice.
    Lew L
    2014 RTS , Circuit Yellow
  11. #61
    Durham,Maine
    Please put it out of it miserly!!!
    2012 RTL , Pearl
  12. #62
    Durham,Maine
    Quote Originally Posted by Lew L View Post
    Help
    Lew L
    I would go get the Metric, that's for the wet clutches
    2012 RTL , Pearl
  13. #63
    Durham,Maine
    I love a good car wreck!!!
    2012 RTL , Pearl
  14. #64
    That's automotive oil, extended life. Not sure it's even 100% synthetic.
  15. #65
    Mar 2015
    Well it says it's 100% synthetic on the bottle. It will be great in my Magnum R/T
  16. #66
    Wa.
    So Bob the oil guy i take is not impressed with rotella T6 oil an couple other people here are not going to use it anymore. I have 5 gallons of it for my spyder oil changes for the next few yrs. So ? is if I go ahead an use it should I change it out around 5,000 miles instead of closer to 9,000 miles which I doubt I will get to that many miles in a yr. anyway. Or be like some others and switch to another brand, I can use t he T6 in my pickup.
  17. #67
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    I use Crisco Vegetable Oil.
    I find that sometimes, I need a burger along the side of a scenic road, so I stop and set up my portable Weber grill. I then apply a THIN coat of this oil on the grill bars by turning my Fumoto drain valve for just a SPLIT SECOND, otherwise my burger tastes like burned 91 octane Chevron gas.
    It's great !! Try it !!!!
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
  18. #68
    Durham,Maine
    Quote Originally Posted by Peacekeeper6 View Post
    2012 RTL , Pearl
  19. #69
    Active Member ChicagoSpyder's Avatar
    Chicago
    2018 F3 Limited , Black/Chrome
  20. #70
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Shell Rotella T6 5W-40 Full Synthetic Heavy Duty Diesel Engine Oil is it ok to use in the 1330 motor ?
    richie spyder
  21. #71
    Durham,Maine
    Whyyyyyyyyyyyyyyy, Whyyyyyyyyyyyyyyyyyyy!!!
    2012 RTL , Pearl
  22. #72
    Sep 2014
    USA
    Those Magnums with the MDS are really finicky when comes to oil. If I remember right they use 5w20. I had to make sure I stuck with the oil or the MDS would act up in cold weather.
  23. #73
    Sep 2014
    USA
    Just let it run its coarse.
    I been running Amsoil Metric 10W40 now since the start and have no issues with it. In fact I found it helped cut down on the clunking when shifting. JMO
    Carry on!
  24. #74
    Durham,Maine
    Carry on!
    That's the same thing I found, works great for me also!!!
    2012 RTL , Pearl
  25. #75
    Nov 2012
    North Las Vegas, NV
    Hard to believe your 10W40 Amsoil shears down to a 20W. I have tested it at 9,600 miles and it was still a 40W.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
