Page 1 of 4 1234 LastLast
Results 1 to 25 of 84
    Jul 2011
    Mitchell, Ontario, Canada
    Default No discussions on oil lately. So maybe time!!!
    Found a good video discussing oil viscosities for automotive. I know this is for car engines but basically applies to our Spyders. Be nice.
    https://youtu.be/IKdhgKUZhPA
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Since XPS only rates their 5W40 up to 104 F, I went with 10W50 for my Ryker.
    112 F forecast for Las Vegas Valley this week (124 F in Death Valley)
    Oils well that ends well.
    Sep 2009
    La Valle, WI
    The guy is saying not good to go up in viscosity on cold number. BRP recommends 5w40. Many here are using 10w40. So are we ruining our engines?
    2018 F3 Limited , Oxford Blue
    May 2020
    New Mexico
    That works even better when pronounced by a Texan (awl = oil)!
    May 2020
    New Mexico
    Quote Originally Posted by JP58 View Post
    That is generally good advice for very cold weather areas. For hot areas, the concern is the upper number.
    BRP recommends what they have.
    Originally, the 998 Rotax was built for the Aprilia - Recommended Lubricant: 20w-50 Oil.
    BRP modified this engine to get more torque, sacrificing HP, for the Spyder. Recommended Lubricant: 10w-40 Oil.
    BRP consolidated their lubricants, several years later, from many to just a few. These remaining lubricants have to cover everything from a snowmobile, which may sit overnight (or longer) in sub-zero temperatures. To side-by-sides, our Spyder/Ryker's, watercraft, etc. You need a very low, cold start viscosity number (0w or 5w) for a snowmobile. But you need a high number (40 or 50) for an off road vehicle or our Spyders running in much hotter temperatures.
    Another factor is, the wider the spread between the low number and the high number. The less stable the lubricant is. So, you really want the narrowest spread that will get the job done for your application. Because your Spyder/Ryker probably does not need to be started with an oil temperature in the sub-zero range. You really don't need a 5w oil. This is why a 10w or 15w-40 oil is actually a much better fit for the Spyder/Ryker than the BRP lubricants. A full synthetic 10w oil will get you down to a zero degree cold start. Most of our Spyder/Ryker's never see cold start temperatures anywhere near this cold.
    Some people tell me they ride their Spyder/Ryker in sub-zero temperatures. But this has no bearing on what oil viscosity is needed. It's the cold start temperature of your machine (Oil) that is critical. Once the engine is running, it doesn't really care what the ambient air temperature is.
    For someone running much of the time in 90 degree to triple digit temperatures. A 20w-50 weight oil is not a bad idea. You'll loose some fuel mileage. But it will be minimal. And engine protection is more important.
    Lubricants have come a long way in the last few decades. We now have 'One Size Fits Many' products. But you can still get better service if you more closely match your needs to a lubricant that best fits the conditions.
    Feb 2012
    Spring City,Utah
    that was pretty slick
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Northern Kalifornia
    "Another factor is, the wider the spread between the low number and the high number." Prior to the demise of Mechanix Illustrated, Ron's comment was addressed in one of the latter issues. Recommended use of oils (at that time) with a range greater than 10W30 was discouraged. Reason being was that the modern additives in oils increasing their high and low applications, built up over time in the piston ring groves decreasing the function of the rings. Exactly what those additives were and if they're still being used today, I don't know.
    Jun 2011
    Near Lexington, NC
    I read Bob is The Oil Guy forum all the time and a number of oil tests of Rotella T6 synthetic 5W-40 in motorcycles showed that it sheared quickly at 2K or less. I have that in my F3T now but don't intend to run it longer than 2K miles. I think a number of folks run the T6 in their Can Am's and wonder if any have had the oil tested at 5K or higher?
    I did read one detailed report from a car guru who noted that oil tended to shear down to upper 20, low 30 range quickly but then evened out for the next umpteen thousand miles. Maybe that's the case with motorcycles, but inclined to think that our wet clutch transmissions cause most of the shearing.
    Anyway, I plan on going with 10-40 Amsoil my next change.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Mar 2015
    forrest above Reno, Nv
    I'm also switching to 10W40 Amsoil soonest. I had planned on the switch from Rotella BEFORE I read this thread.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2013
    Marion, Arkansas
    I used Amsoil 10w40 in my previous Spyder a 2015 RTS and still using it in my 2017 F3L
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jul 2011
    Rotella T6 5W-40. Shell has removed all mention of being suitable for motorcycles. From both the jugs and online literature. But the specs still say meets JASO MA/MA2.
    Rotella T6 0W-40. Shell has never listed it for motorcycles and does not have the JASO clutch slippage spec listed at all.
    That is what they have done in Canada at least.
    May 2020
    New Mexico
    That was a valid concern in the 1970s with 10W40, but as you stated at the close of your post, "Lubricants have come a long way in the last few decades."
    10W60 (specified by MG) Motoul worked very well in my Moto Guzi in temps up to 116F.
    Sep 2016
    Chillicothe, Oh.
    When was the last time anyone here had an oil related engine failure on anything they own?
    2015 RT , Black
    Clinton, MS
    Not sure you meant it as a question or an actual statement, but, modern "major brand" oils are for the most part so good i don't think oil related failure enters into the picture.
    Aug 2019
    Stoughton, WI
    I'd really like to see an oil analysis of Amsoil/M1 10w40 or Castrol 10w50 after a BRP stated 9000 mile run time. Has anybody ran their oil for 9k miles?
    2022 RT Sea To Sky
    Dec 2019
    Land of Lincoln
    Everything BajaRon said.
    I currently have Motul 7100 10w40 in my 19.
    I will be switching to the 300V 15w50 in the spring.
    Looking at specs, it barely nudges into the 50 weight range, and with the heavier base oil, should maintain viscosity well over the change interval, shearing into a 40 weight range and staying for a while.
    My 12 had a lot of different oils in it, (I experiment) but the stand-out used oil analysis was on generic, black bottle Havoline 20w50 conventional. At 4000 miles in, it was still testing at a 20w40, with some shear present, and very low Fe numbers (iron) that tracks higher with mileage. The VTwin shears oil, and 40 weights (usually) drain as 20 weight oil at 4000 miles.
    Just so it's not considered to crude.
    There is a spectrum between 'Failure' and 'Optimal'. I think this is where a discussion on lubricants is valuable.
    Oils have improved because engines have improved. And vise-versa. Machined tolerances in today's engines are much smaller. Plus, the energy output per cubic inch has increased a great deal. Internal pressures and temperatures are much higher than in days gone by. Modern engines would not be able to function for very long without the current improvements in lubricants matching the the requirements.
    May 2020
    New Mexico
    Yes.
    Quality brand
    Viscosity appropriate for ambient
    Change before particle suspension is heavy (oil analysis or no, 9,000 miles is a concern)
    Feb 2012
    Spring City,Utah
    That was shear genius.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Quote Originally Posted by SportsterDoc View Post
    Yes.
    Quality brand
    There are some very interesting aspects to this which have never been (nor will likely ever be) addressed.
    The service interval on the 998 V-Twin has always been 4,500 miles from the beginning. This makes perfect sense when using the BRP lubricant because innumerable tests consistently show it begins to shear and lose viscosity in a steep decline at this mileage.
    Fast forward to the 1330 triple. Same oil, same steep decline in viscosity at around 4,500 miles. But a magical service interval of 9,300 miles. This means the typical 1330 owner is running 20 weight oil for close to 5,000 miles between each service.
    Now, to be fair, there have been, to my knowledge, no 'Engine Failure's' reported, as mentioned in a previous post. So, does this mean that the 1330 is fine with 20 weight oil? If so, why not spec. a 20 weight oil to start with? And why continue to recommend a 4,500 mile service interval for the 998 V-Twin if running at 20 weight is a good idea?
    Granted, we are talking just a bit of apples and oranges here, since we've got 2 different engines. But you can't escape the fact that the lubricant performs pretty much identically in both systems.
    ...Has anybody ran their oil for 9k miles?
    I do it every oil change with Amsoil Metric Full Synthetic 10W-40. Here are all the analyses I have had done. The first one with Amsoil had excess condensation because my winter morning trip to/from the gym was too short for the oil to fully heat up so I tripled the distance in the subsequent analyses.
    May 2020
    New Mexico
    ...The first one with Amsoil had excess condensation because my winter morning trip to/from the gym was too short for the oil to fully heat up so I tripled the distance in the subsequent analyses.
    Very good excuse for a longer ride!
    When I had my Sportsters, it was only 7 miles to my shop.
    In SoCal winters, oil barely got to 155 F in the mornings...so I left earlier and took longer ways to work.
