Results 1 to 8 of 8
Thread: Tranny Question
    Active Member Gedge's Avatar
    Jun 2020
    Claypool, In.
    Default Tranny Question
    Hi all, I've had my 2019 F3 Limited for about a month now. It has about 1100 miles on it. I've noticed in the past couple weeks or maybe when I got it, just didn't notice, that it takes more twist of the throttle to get her moving when first started, but she goes and shifts just fine when warmed up. Has anyone else noticed this and should I be concerned?
    Thanks Gedge
    2019 F3 limited , Black
    Nov 2018
    Trinity, NC
    My 2018 F3-T is the same way. Takes a bit more throttle when cold to get moving, but once warmed up all is well. Mine has done it since I bought it new. I believe it is normal.
    When the engine is cold the internal oil temp may affect how the HCM functions, perhaps slowing just a bit the lock up of the clutch. Just a WAG.
    Quote Originally Posted by Southpaw58 View Post
    ... I have a 14 RT ... and if cold it is initially sluggish about moving ..... as it warms up this dis-appears ..... Mike
    Feb 2019
    Portland, Oregon
    This is why it is why it's best to allow the engine to warm up while putting on your gear. I warm it until the first coolant mark appears.
    Jun 2011
    Near Lexington, NC
    Normal....oil has to circulate thru wet clutch.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Mar 2017
    Relation of the Throttle Position sensor and the fast idle at cold start. You will note a greater twist needed when cruise is set too
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    No need to warm up just start your Spyder and go
