Adjust angle of floorboards on 2014 RT
Is there a way to adjust the angle of the driver floor boards mine seem to be angled down a lot at the front.
They're supposed to be angled down some towards the front. If the right board is angled more than the left, that's sort of normal as that happens when someone steps on the brake HARD. If that's the case, you can just pull up on the front of the right board. If both are even, it is what it is.
The footboards were designed that way. In the event of HARD braking, the board will go down even further to allow for full braking.
Never had it happen to me, but good to know it is there anyway.
