Results 1 to 10 of 10
    Invalid Emails
    Aug 2019
    Elizabeth City NC
    Default Amber strips on front fenders
    Is there a kit to make the amber strips on the front fenders of my 2014 rt limited light up.
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by bikerpipes View Post
    If you're talking about the reflectors, then absolutely. Both SlingMods and LaMonster have them. I'd go w/LaMonsters as his is as close to plug and play as you're going to get but SlingMods are the 2nd gen and LaMonsters aren't.
    Active Member LongIsland's Avatar
    Dec 2018
    Long Island
    Tricled sells them as well.
    Sep 2014
    USA
    Yep TRICLED has them and I do too.
    Bossier LoUiSiAna
    There are kits mostly will light up with turn signals not just running lights
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    + 1 for tricled
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    I have the 14 RT with the basic fenders .... I wanted the outer edges to be more visible so drivers coming from the rear would notice where my front wheels were .... I found some 18 inch long LED strips ( amber ) that were only 6mm wide. .... because they were thin I was able to follow the arc of the fender without any kinking ..... with the normal 12 to 15 mm wide ones they can't be arced, they would work in the center of the fender, in a straight line ..... Mike
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by bcer960 View Post
    + 1 for tricled
    +2 for the sequential and very bright TricLed " Fenderz" lights. Dimwitted drivers will see these.
    Lew L
    2014 RTS , Circuit Yellow
    Aug 2019
    southwest oHIo
    I got a set of the TricLED fender lights from Value Accessories. Installation was relatively easy. The hardest part is tapping into the turn signal wire, but I had most of the front off anyway for a bunch of other stuff I was doing.
    Yes, they DO grab attention. I think the only complaint my wife has (it's HER Spyder) is that there is a bit of glare from the lights at night. Fortunately, the chin bar on her helmet blocks most of it, but it's still there.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Aug 2013
    SF Bay Area
    I made my own. Fun and way cheaper.
    2021 F3 Ltd , Magna Red
