Results 1 to 9 of 9
    Active Member tbohman56's Avatar
    May 2020
    Greenwood, SC
    Default Treal Performance Anyone?
    Has anyone actually purchased and received the Treal Performance Exhaust System for the Ryker? I noticed on one vendor site it says "Pre-Order and Awaiting Parts - NO ETA". Is this a wait and see how many will order before we put into production? Or a Covid-19 thing?
    Currently Own: 2019 Ryker Rally
    Previously Owned: 2019 F3 Spyder
    It sounds like #1 is a good possibility.
    Quote Originally Posted by tbohman56 View Post
    Your Ryker has a computer controlled " engine management system "..... which knows how to adjust itself to cancel any of what used to work for Non-controlled engines that were common decades ago. If you just want to change the sound, that's all it will accomplish ..... good luck .... Mike
    May 2020
    Greenwood, SC
    Dyno shows some increase in HP and Torque with Treal exhaust and Dynojet PV3. Is it worth the money? That's another question.
    https://youtu.be/D3hbU3_4uVI
    I have heard this ..... " It has to be true - I saw it on the INTERNET ".... IMHO ( and others here ) believe that " re-mapping " the ECU is what is needed to get better performance ..... annnnnnnnd in your original post you didn't mention the " Dynojet PV3 " !!! .... That's like saying I put a " Borla " performance exhaust on my car and knocked 2 seconds off my 1/4 mile time ..... However you forgot to mention you also added a " Super-charger " ..... Answers you get here are based on the info that is provided ..... good luck .... Mike
    May 2020
    Slidell, Louisiana
    from what i have been reading. treal has been having supply issues and is working to get all back orders out. they are the only exhaust to have dyno numbers to prove hp gain.
    with the pv3 and a stock ryker you can retune and gain around 20 hp just from having the fueling remapped. not to mention, speed limit removed, change your throttle sensitivity, adjust for max torque etc.
    Dave
    May 2020
    Greenwood, SC
    In my original post I wasn't asking for performance comments . . . I was only asking if anyone had purchased.
    Sep 2017
    Durham,Maine
    Mike you never let the whole cat out of the bag!!!
    2012 RTL , Pearl
    You are correct ... I shouldn't have tried to pass on, what I believed to be useful accurate information ....... I WON'T MAKE THAT MIS-TAKE AGAIN WITH YOU ....... ride safe - ride happy .....................Mike
