Hello!
Picked up a 2020 F3-S Special Series and would like to put in a charging port. I have a wired accessory circuit cable connected to one of the caps under the handle bars. Is there a plug and play USB port I could use that would fit? Attached photos of the connection.
You might find a USB port to put into the Hole but then you'd have to run power to the cable under the left panel to the customer accessory power which is zip tided to the frame. That cable is for Heated Hand Grips.
