Results 1 to 3 of 3
    Member perry s's Avatar
    Apr 2016
    hamilton ontario
    Default no power, battery OK, what next?
    turn on key no power tested battery 12v on tester what do i check next 2008 sm5 perry
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    When you tested the battery was it when you were trying to start it or just at rest? At rest voltage should be more than 12v. How old is the battery? Try doing a load test on it and check the battery connections.Good luck.
    Bob S
    Mar 2015
    forrest above Reno, Nv
    This is what happened to me today :
    Filled up fuel at the local station. Went to start it and no go. Is it my time for problems???? NO- after pushing a few buttons ----- I touched the KILL SWITCH and it started right up.Must have nudged when getting off the for fueling. Only did this once before on a trip with my beloved on the 900F.
    Lew L
    2014 RTS , Circuit Yellow
