Can't get left mirror to snap back in at bottom front?
Any ideas? The top slides and catches, the bottom rear snaps, but not the bottom front.
see if the wires of the clip are bent, if they are replace the clip.
Honesly, I'd suggests buying a set of LaMonsters Magic Mirror attachments. It uses some super magnets and you can avoid those hassles.
Thanks folks, I ordered 4 springs for $12.00 from my dealer.
Like my magic mirrors great stuff
RT-S PE#0801
They will just bend again the next time they are removed. The magic mirrors are the way to go!!!!!!!!!!!
You can straighten those old springs out and save $12 for a set of Magic Mirrors, lol.
SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
2016 Toyota Sienna SE - hers
2002 BMW 325i - his
1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
2018 Can-Am Spyder RT Limited - hers
2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
2011 Tao Tao 50 - whoevers bike is in the shop
2007 Reinell 186 FNS - the dog's
1995 Fleetwood Flair 27R - EVERYBODY'S !
I've been using the OEM mirror clips on my Spyder for 67K+ miles and have never had a problem with the mirrors being firmly anchored to the bike. Why? The first reason I firmly believe is I learned right off the bat how to properly remove and reinstall them. Shawn Smoak's videos on doing a 1330 engine oil change show how it's done. Second, each time I remove a mirror I check the springs and if they are bowed I straighten them. I also keep a couple of spares readily at hand but have had to use one only once when a dealership bunged up one of the original ones so badly I had to chuck it. At the same time I also clean the springs with some 4-aught steel wool because they will accumulate come corruption on then due to weather exposure. Lastly, before reinstalling a mirror I clean the studs and wipe a very, very thin film of white lithium grease on the head, and I mean only the head, of the studs. You don't want to use so much that a spring can carry any grease into the groove of the stud that holds the spring snug.
If you buy the Magic Mirrors, you won't have to deal with all that extra stuff. It is MAINTENANCE-FREE. Screw them on and you're done for the life of the bike.
Sure it's $100, but isn't the time you save doing all the crap with the springs, studs, grease, etc., etc. worth it ????
Plus, even with stiff springs, there's a little bit of play resulting in slight blurriness when you look to see what's behind you. The MM virtually eliminates that play, resulting in clearer images.
That, to me, is worth it.
Reason: edit
2002 BMW 325i - his
Two words:
Magic Mirrors
2002 BMW 325i - his
Originally Posted by Peacekeeper6
Two words:
Magic Mirrors
+1
Lew L
Originally Posted by Lew L
+1
Lew L
+2
IMHO, the MM should be THE first mod you install on an RT. It just makes your life that much easier.
2002 BMW 325i - his
And here's my philosophy in why the MM are an important and ingenious mod:
Anytime you bang those things to get them off, you're doing a disservice to those turn signal bulbs in the mirrors. I'm betting that the MM lengthens the life of those bulbs. Plus, there's something not quite right about hitting your bike with such force. One of these days, it's not gonna like it and will leave you stranded on the road.
So treat your bike right. Get those MM, save time and energy trying to fix those damn springs. Unless you really enjoy dicking around with them and making them straight again over and over and over, then ignore my advice.
(BTW, I do NOT hold any stock in the company that makes Magic Mirrors).
Reason: edit
2002 BMW 325i - his
I have Magic Mirrors also, but before I got them I put a washer under the post that was hard to snap into place and that made it much easier.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Just upping my post count.... er +1 Magic Mirrors
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
SpyderLovers Sponsor
A spritz of WD40. Goes right on. I do them all the time. Magic mirrors are cool. The stock clips work fine.
Joe Meyer
