Results 1 to 23 of 23
    Apr 2015
    Grand Forks, ND
    Default BPR Connect / AccuWeather Help
    When setting up BRP Connect on my iPhone I want to move AccuWeather from the lower section of the screen to the upper part of screen So it will show up on the dash any idea?
    Jim
    Apr 2015
    Grand Forks, ND
    How do I get AccuWeather to show up on my dash?
    Jim
    Apr 2015
    Grand Forks, ND
    My Spyder is a 2018 RTL
    Jim
    Aug 2013
    SF Bay Area
    All we can do is email or call BRP Care and bug them to update things. I believe, since the OS update to phones, BRP Connect needs updating and possibly the dash.
    Call or email them.
    I have a 2018 RTL and it was there and now it's in the app as a new app to install. The dash doesn't see it.
    2021 F3 Ltd , Magna Red
    Apr 2015
    Grand Forks, ND
    Flame winger
    I have the same problem as you the AccurWeather app is in the apps to load but it will not load like all the other apps listed will. AccurWeather did a up date to there app a few days ago wonder if that caused the problem. Can any one help us out?
    Jim
    May 2019
    New Mexico
    One thing to check for whenever any app seems to not load/misbehave:
    The app may be 'asking' for new permisssions. I've noticed that this (the permissions dialog) will show up on the phone - but not on the spyder's display. Once you click the ok in the permissions dialog (on the actual phone itself) the app will then work as normal. You can check this with the phone still USB attached to the Spyder.
    Another tip (Android): Set your lock screen to a long timeout. This way, when you're at a gas station, your phone doesn't revert to a locked screen, which is a no-no for Brp Connect and will force you to unlock the phone. This is a PITA if your phone is sitting in the frunk.
    Beware if you have a phone case with a folding cover - some of these will trigger your phone to automatically go into lock screen mode.
    TIA
    Active Member kissfan's Avatar
    May 2019
    Brooker, FL
    BRP Connect has an application list with a 'fingerprint' of the supported app. It periodically gets pushed to your phone.
    When AccuWeather updated its app to the new release about 3 weeks ago, its footprint changed.
    BRP hasn't removed their thumbs yet and updated our phone inventory of validated apps. So... AccuWeather (and FOBO2) still won't load into BRP Connect.
    Send BRP a nastygram, I did as soon as it happened and have yet to get a response from them.
    My vice is passion for KISS.
    Oh, and food.
    Current ride: 2019 Spyder RT-L in Phoenix Orange.
    2019 RT-L , Phoenix Metallic Orange
    Apr 2015
    Grand Forks, ND
    How do you contact BRP ? Does anyone have a email address for the right department?
    Jim
    May 2019
    Brooker, FL
    Quote Originally Posted by JimboRTS View Post
    Jim
    https://can-am.brp.com/on-road/us/en...ontact-us.html
    Oh, and food.
    Apr 2015
    Grand Forks, ND
    I contacted BRP about the issue of Accuweather not loading to BRP Connect and they are aware of the problem and are working on fixing it.
    Jim
    May 2019
    Brooker, FL
    Jim
    BRP makes me want to continue drinking.
    On your phone is a list of apps that are allowed to be used, and a 'fingerprint' of the supported application. When AccuWeather changed, so did the fingerprint. All BRP has to do is push out a new inventory file with the supported fingerprint and it'll work.
    You can see when it was last downloaded:
    BRP Connect -> Options -> Information -> Version (look at "update app list")
    Oh, and food.
    Nov 2018
    Trinity, NC
    Not sure what is different about my set up but I was messing around with BRP Connect on my 2018 F3-T today trying to get the Cardo app to work (without success I might add), and I went into the AccuWeather app that was showing on the bikes display. It all seemed to work just fine. Pulled up my locations, gave me the current conditions, and hourly forecast. Ended up deleting it all though. I use Amazon Music while riding, and it won't work through BRP Connect.
    Cheers
    Bill
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    Quote Originally Posted by kissfan View Post
    I discovered that, at least for BRP Connect on iOS, you can tap on "Update app list" and it will download the latest version.
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Nov 2018
    Trinity, NC
    I should have added that I use an Android Samsung Galaxy S7 phone.
    Apr 2015
    Grand Forks, ND
    Not sure but it appears if AccurWeather app is updated it will not load to BRP Connect. It may work if you have the old version.
    Jim
    Jul 2020
    Austin, TX
    Jim
    Second that, they just updated the app, and it disappeared from BRP Connect, you can see it in the mobile app list, but it's not displayed on the panel.
    2020 Can-Am Spyder RTL
    2009 Yamaha V-Star 1300T (sold)
    2007 Yamaha V-Star 650 (sold)
    "I wasn't born in Texas, but I got here as fast as I could!"
    2020 RTL , Asphalt Grey Metallic
    Jul 2015
    Dorr, michigan
    I am having that same problem with accuweather on my new 2020 RT and my android phone. Does anyone know if there are any fixes for it as of yet, and if so what I need to do to make it work?
    Thanks
    2020 RT Limited , Petrol Blue
    May 2019
    Brooker, FL
    Quote Originally Posted by Fatcycledaddy View Post
    Thanks
    Nope, not yet updated by BRP. All you need do is have patience... once BRP gets it together, the'll push an update to your phone and AccuWeather will 'magically' work again.
    Oh, and food.
    Jul 2015
    Dorr, michigan
    How do you tell what version of BRP connect you have?
    May 2019
    Brooker, FL
    On iPhone...
    Menu in upper left corner
    Information
    Version
    Oh, and food.
    Aug 2013
    SF Bay Area
    IN the dash you push joystick in then down to the gear (Settings) then find about. That tells you what firmware you have.
    Apr 2020
    Upstate NY
    BRP Connect sounds like a PITA.
    Current Rides:
    2015 Spyder ST-S SM5
    2016 Honda Gold Wing ABS/Navi
    2022 Royal Enfield Classic 350
    2021 Royal Enfield Himalayan
    May 2019
    Brooker, FL
    Quote Originally Posted by VStarRider View Post
    If only it was that good.
    Oh, and food.
